SLOW FLASHING AIRBAG LIGHT
Old Apr 18, 2010 | 05:32 PM
95maxse3000's Avatar
i have a 95 maxima. and the airbag light was flashing really fast. then i read on here how to reset it( open both doors hit the door switch 5 times and start the car) well i did that and all it did was slow the light down to about 5 seconds on then it will go out for 5 seconds and then back on. what should i do to get it to go out. is it a serious problem?
Old Apr 18, 2010 | 06:43 PM
komik's Avatar
That doesn't exactly reset the light, it just changes from "User Mode" to "Diagnostic Mode". Though, from there the system should reset if there is no longer a malfunction. Here is what I posted in a similar thread.
Originally Posted by komik
If there is a problem with your airbag system (which it sounds like there is) the above "tricks" won't help you. If the Air Bag light is flashing, that means there is or was a problem. Pressing the button 7 times does not reset the light, it changes it from "User Mode" to "Diagnostic Mode".
From the FSM:
There are four flash codes in "User Mode" upon turning the ignition on:
1. On for 7 seconds, then off - No malfunction detected.
2. On for .5 sec off for .5 sec, repeat - Malfunction detected.
3. On - Airbag deployed.
4. Off - Control Module or Warning Lamp shorted.
In "Diagnostic Mode" (after pressing the DDS 7 times in 5 seconds) the flash codes are:
1. Off for 2 seconds, On for 3 seconds, repeat - Intermittent problem has been detected in the past. (Light should reset after turning key off).
2. Off for 2 seconds, On for 3 seconds, Off for 2 seconds, X flashes, repeat - Malfunction indicated by value of X below:
2 - Driver's air bag module circuit is out of order.
7 - Diagnosis sensor is out of order.
8 - Front passenger air bag module circuit is out of order.
What you are describing sounds like the second #1 above. Have you done anything recently that might have tripped the light? I had a problem getting my air bag light to go off after I replaced my clutch because I forgot to reconnect both air bags before the battery. What eventually solved it was putting the system in diagnostic mode, turning the key off, disconnecting the battery for a little while, then reconnecting it.
Old Apr 18, 2010 | 06:49 PM
i havent tryed anything to get it to go off. i have played with some wires under the seat it didnt make a diffrence. The light was flashing when i bought the car a year ago.
Old Apr 18, 2010 | 07:02 PM
komik's Avatar
Then it's probably just an old code. Some combination of button pressing, key turning, and battery connecting should do the trick. Mine was on for almost two weeks before I got it to go away. At one point I called a local dealer to see if they could help. They said for $120 they could hook a computer up to the car and clear it. I told them it should reset by pressing the button and they told me they couldn't help with stories I heard on the internet.
Old Apr 18, 2010 | 07:09 PM
lol they can be di*ks they will do anything to get a dime out of you
Old Apr 20, 2010 | 09:25 PM
ejarmol's Avatar
from the stickies (works for me every time the light is set off after I vacuum my car or plug/unplug my ipod interface under the passenger seat):
OMG MY AIRBAG LIGHT IS ON!!!
Airbag Light Fix (revised)
IF YOUR AIRBAG LIGHT IS FLASHING WHILE YOU DRIVE 9 times out of 10 it is the passenger seat side air bag...the one that is inside of the seat...what you need to do is the following:
Open your door and first locate the button on pillar A....this little button is the drivers door switch and when the door is closed the button is pressed in making the car know that the door is actually closed....it is a small button with black rubber surrounding it. Once you locate it, turn your key to the ON position....DO NOT start the car...simply turn the power on so the engine light, battery and everything else is lit without engaging the ignition. Then with the key in the ON position press the drivers door switch at least 10 times within 10 seconds with your finger: in and out in and out fast......then once you have done that turn your key to the OFF position....when i did this I found it easy to turn the key half way between where you take it out and half way between ACC so nothing should be getting power...not even the radio but you should also not be able to pull the key out. Then close your door and with the key in that same position, between taking it out and ACC, start the car by turning it towards the ignition. This means don't take the key outta the ignition the whole time.
If you have a 99 9/10 it is the passenger SEAT airbag....the one that is actually in the seat and Nissan will try to tell you it is faulty but by doing this you will engage the system so it will work again. I know people that have had the seat air bag repaired and then the light has come on within a year. If it was the airbag that was in the dash I would say get it fixed but with it being a seat air bag even if it doesn't work the rest of the system will. Same thing happened to me and I got it diagnosed luckily for free at the dealership but then did the thing above and it hasn't come back on in over a year and a half. A lot of times they said it could be caused by a passenger having their feat under the seat where the air bag components are.
Print this out and GO DO IT NOW!!!! It works.....mine went on in March 2004 and I was told by Nissan I needed a new passenger side SEAT airbag....the side curtain on that is INSIDE the actual seat of your car if you have it. Nissan said it was VERY common and it is faulty.....amazingly they even had some on-hand....follow this how -to!
Old Apr 20, 2010 | 09:46 PM
FallenOne's Avatar
Allow me to sum up what the previous user said...
Move the Seat. Forward, Backward, Up Down. Than check it again.
/thread
Oh yeah thats right, because its the Org and we just tell stories, None of us are mechanics or DIY'ers by any means
/Dealership Fail.
Old Apr 20, 2010 | 11:36 PM
defiance's Avatar
IF YOUR AIRBAG LIGHT IS FLASHING WHILE YOU DRIVE 9 times out of 10 it is the passenger seat side air bag...the one that is inside of the seat...what you need to do is the following:[/quote=ejarmol;7524291]
He has a 95 There are no seat airbags...
Old Apr 21, 2010 | 08:27 AM
this actually worked i did it and the air bag light went out and has not come on.
Old Apr 28, 2010 | 12:04 PM
99 SE-L Max's Avatar
WORKS!
This worked on my second try, I'll see how long it keeps the light off.
Just be sure when you put it in acc mode, that you turn the key to the point when all the lights on the cluster come on, not just to where the clock and radio work, one turn past that.
Old Apr 28, 2010 | 12:06 PM
FallenOne's Avatar
Like i said, jsut move the passenger seat around...
Old May 20, 2010 | 06:34 PM
Diamond Joe's Avatar
This fix worked for me! THANK YOU ejarmol!!!
Old May 25, 2010 | 02:55 PM
ejarmol's Avatar
yeah sometimes it takes a few tries, but always works. FallenOne you can suck it buddy, moving a seat around isn't going to put the srs system into diagnostic mode to recheck the system and reset the light
kthx
Old May 25, 2010 | 06:11 PM
FallenOne's Avatar
kthx
Wow, You sir are a Moron. First off if you dont correct the goddamned problem its not going to drop the code so you can rid yourself of the goddamn trouble light. Im pretty sure we had already established the fact that it needed to be set into and out of diag mode.
But how on earth do you fix the problem?
MOVE THE FREAKEN SEAT AROUND. HOW DO I KNOW? OH IVE DONE IT.
KTHX@$$BAI
Old May 25, 2010 | 07:57 PM
adamsanders's Avatar
KTHX@$$BAI
Yeah buddy, don't hide that immaturity!
Old Jan 4, 2015 | 11:16 PM
max ride 41's Avatar
so i'm bumping an old thread cause my airbag light in my 95 started flashing last friday and obviously these little tricks did'nt work. anyone else know what can cause the light to come on?? it flashes on for 3 seconds then off for 3, just came on randomly after car sat at work one day.
Old Jan 4, 2015 | 11:47 PM
JoshG's Avatar
mine has been flashing for 2 years now, and i know exactly why, my friend put my passenger seat all the way back and down, stretched the wire underneath it probably.. havn't tried the reset method... but im positive he stretched the wire underneath the seat, the light came on 1-2 days after he did that. sucks..
mvm062
Nov 30, 2020 09:00 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
Maxima30
Sep 7, 2015 06:13 PM
intimidator
Sep 5, 2015 07:23 PM
