Drop the tranny pan and change filter?
Old May 15, 2010 | 07:01 AM
Kryogen's Avatar
The dealership told me they had to change my oil when the tranny started acting bad. They just drained and refill.
Is there a filter that we have to change somewhere? I mean, aint it better to drop and clean the pan, change filter, etc?
Thx
Old May 15, 2010 | 07:08 AM
po8pimp's Avatar
yes it is better to drop and clean and change filter. You have to ask for that service which costs more due to labor fees. Also the dealership will try and sell you on the flush service.
Old May 15, 2010 | 07:10 AM
KCMAXX's Avatar
KC's FINEST
lol
Old May 15, 2010 | 08:16 PM
Kryogen's Avatar
What do i need if i drop the pan? gasket, filter, fluid, thats it?
Old May 15, 2010 | 09:28 PM
Red line's Avatar
the best thing is when you change your oil you must change your fillter
so the way to do is :
1_ change oil with filter
2_ cahnge oil
3_ change oil with filter
4_ change oil
& do it by that way
so when you see the oil is almost black
clean your engine * change the fillter * Change the oil
i hope so you have been understand what i mean
Peace
Old May 15, 2010 | 10:26 PM
NismoMax80's Avatar
SuPeRmOd
if your transmission oil ever gets black... i think there is not point in bothering anymore...
Old May 16, 2010 | 11:06 PM
2o4Max's Avatar
I looked at this as well, and after reviewing the drawings I did not see a filter of whatsoever for the 5AT at least. Most likely if there was a filter it would have been on the 4AT as that could be power flushed. I'm not certain of the CVT tranny,(06-08). I double checked with the transmission shop I trust, and they told me as I had thought after reviewing the drawings the 5AT was designed as a sealed unit and that it should last for the life of the car with just draining and filling.
Old May 17, 2010 | 03:43 AM
Kryogen's Avatar
Right, checked the manual, there is no filter for the 5at.
How much oil drains when you drain it? 3,4,5?
Old May 17, 2010 | 11:22 AM
2o4Max's Avatar
Approximately 4qt/4 litres, haven't done it yet. I did have about almost 4 litres readded when the transmission cooler seal was replaced due to a leak I had. I will be doing another drain and fill in about a month or so just before my road trip. Make sure you get a new drain plug gasket, and torque the hex ATF drain plug to 29 ft/lbs. Since I don't know if you are in Canada, if you are, you will need a 10 Hex socket to torque the drain plug.
Old May 17, 2010 | 05:47 PM
Kryogen's Avatar
Ya, I need to buy that damn hex socket kit when it's on special at canadian tire next time. For some reason I never got it.
kjlouis
Oct 3, 2015 05:29 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
Lowered_a33
Sep 1, 2015 07:49 PM
