Which light blinks on the altezzas?
Re: Re: the
Originally posted by baby_boy21
Which one is it....the little clear one or the big red brake light??
Originally posted by ny96max
the red dot will blink. My boy rewired them so the small push bulb blinks instead of turning on with the parking lights. IMHO it looks 1000 times better, plus you can actually see his blinkers at night.
all you need to do is the following:
1) take the socket for the small push bulb and cut the wires off(leave about 4" or so at the end of the fixture) MAKE SURE to cap off the other end with electrical tape cause they are live!
2) now strip back each wire coming out of the socket about 1/2"
3) now, without cutting the wires, strip back just the sheathing off the brake light wiring harness going to your brake light bulb. I belive there is like 3 or 4 wires running into it.
4) Turn on your flashers(hazard lights) now take the small socket and wires and touch them to a pair of wires that you just stripped back.
Hope fully you will find the right combo that will make the little light flash
**now im not responsible if you blow a fuse or a light bulb. im saying all of this off the top of my head, without actually looking an any harness to say exactly what wire does what.
Anthony
Anthony
the reason for this re-wire is so that you can actually see the turnsignal flashing. For some dumb a$$ reason APC or whoever designed the Altezza for the max made the brake/blinker intergarted into one lense, making it impossible to see you signal.
So if anything make them just blink, cause people will see the 4 big-a$$ red dots light up fine when you hit the brakes, lol
its the signals that suk in the rear...
Anthony
Anthony
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
