Replacing valve cover gaskets
10 or 12MM socket. a screw diver for the rear VC, a 8MM for the front. you'll also need a allen wrench to get the engine cover off.
your going to need a new TBgasket because the stock one is paper type.
if your going the rear you might as well buy a knock sensor and just take the LIM off and install that while you have everything else off and out of the way
If you are going to do the rear cover gasket, you will need to take off the UIM (upper intake manifold). Org member ATTappman did a nice thread with pictures on 7-26-2009 titled "Removing Upper Intake Manifold (UIM) w/pics".
found the link:
http://forums.maxima.org/4th-generat...im-w-pics.html
found the link:
Matt93SE
Apr 8, 2018 09:23 AM
raffivegas
Aug 23, 2015 09:54 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Nintensity
Aug 13, 2015 05:41 PM
