swap in progress 3.5 5sp vlsd.
Old Jun 16, 2010 | 08:16 PM
maxboy01AE's Avatar
swap is done..
Old Jun 16, 2010 | 09:20 PM
fpromax02's Avatar
a friend and I r just finishing up a 3.5 swap in his A32 went pretty smooth...couple hick ups here and there...good luck.
Old Jun 16, 2010 | 10:23 PM
LONERANGERSR20's Avatar
ooo snap, AE wid 3.5 swap, dats wat up. who doin the swap for u?
Old Jun 17, 2010 | 12:02 AM
CraigSE's Avatar
It looks like its being done in house.
Looks wicked man... Want to see progress!
Old Jun 17, 2010 | 12:20 AM
yaboyrizzo's Avatar
wass supp whos gettin the swap done how much u payin
Old Jun 17, 2010 | 04:49 PM
maxboy01AE's Avatar
the swap im doing it myself and na this aint a house this is my shop. im following the 4th gen write up.. right im stuck cause i need camber adapters.. tensioner wont lined up with the block.. anybody have expireince this before.. is anything also i can do rather than buying cam adapters.. a
Old Jun 17, 2010 | 04:52 PM
MaxCrazy00's Avatar
how much it cost you? all together/
Old Jun 17, 2010 | 05:04 PM
Crusher103's Avatar
i must say that is an interesting way to work on a motor.....
Old Jun 17, 2010 | 05:09 PM
maxboy01AE's Avatar
800 motor 2200 tranny prolly like another 700 when im done
Old Jun 17, 2010 | 05:45 PM
essential1's Avatar
My axles cry for mercy...
You can run your stock dek cams if you dont wanna use adapters if im not mistaken. Only way to run 3.5 cams is with adapters. Get them from stephenmax or JWT.
http://www.jimwolftechnology.com/cus...asp?PartID=491
You will also need the longer dowel pins with the JWT adapters.
I was thinkin the same thing
Old Jun 17, 2010 | 06:03 PM
CraigSE's Avatar
Just for clarification, "in house" does not mean in a house, it means by the person who made the post.
Old Jun 17, 2010 | 06:12 PM
Rods03Max619's Avatar
**** looks pretty wicked don't know if I would have the ***** to do this but good luck!!
Old Jun 18, 2010 | 08:28 AM
Unklejoe's Avatar
Love that you chose to go with a 5 speed.
Sometime I think that if I had a 5 speed, I'd actually be faster...
Old Jun 18, 2010 | 08:34 AM
swap is done..
car runnin good?
Old Jun 18, 2010 | 03:19 PM
Christobal65's Avatar
The gear ratios and the final drive ratio on the 6spd in the 02-03 are nearly identical to the 5spd's gear ratios.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
09maxshawn11
Sep 30, 2015 10:28 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
