vq35 heads on vq30 short block??????
hey i allready did my vq35 swap like 2 years ago till las night when i lost my engine cause the rain by the intake.
i still have my vq30 jdm in good conditions and i was thinkin on putting my vq35 heads on the vq30 short block. do u thinnnnk its a good idea??????????
vq35 swap katback, intake. i push 13.8 @99mph 1/4mille, with 220whp.
Not worth it. If I recall correctly, but don't quote me on it:
1.) VQ35 combustion chambers don't match the bore of the VQ30 block
2.) VQ35 combustion chambers are more prone to detonation than VQ30 chambers, not to mention with them not matching the bore it makes this problem worse.
3.) VQ35 heads on the VQ30 lowers the compression ratio which means you will make far less power NA with 3.5 heads on a 3.0 than with 3.0 heads on a 3.0. Even boosted it isn't worth it because of the above listed detonation and mismatch issues, and the fact that while boosting you can make enough power on 3.0 heads to break just about everything on the car before you run into head flow limitations.
jmlee44
Oct 2, 2022 02:13 PM
