18x8.5 +30?
Old Jul 12, 2010 | 08:01 PM
Flava_24/7's Avatar
Boosted Panda
18x8.5 +30?
Any 4th gens running 18x8.5 +30 in the fronts? If so, care to post some pics?
Im curious to see just how much they would poke out. Please list tire size also if you do post pics please.
Old Jul 12, 2010 | 09:21 PM
Crusher103's Avatar
im on 19x8.5 with a 35mm offset and here is how i sit, tires are 235/35/19 BFgoodrichs(they run wide), so they run pretty wide. they dont rub:
here is a 245/45/18 on an 18x8 with a 30mm offset and it rubs:
unless u have a little bit of fender work(my front fenders are unmodified) i dont thinking a 30mm offset would work to great, i had a slight poke with the 30mm offset but it was barely noticeable looking at the car from dead in front.
hope that helps alittle.
Old Jul 12, 2010 | 09:39 PM
QT1 5MT AE's Avatar
Gram Lights addict
rear z33 tracks v1???? it fits with a stretch. its going to stick out 1-2 mm.
18x9 +32 FRONT 235/40
19x8.5 +35 255
you get the picture...
Old Jul 13, 2010 | 07:38 AM
Flava_24/7's Avatar
Boosted Panda
So in order to stay flush, without the poking out it appears I need an 18x8.5 +35.....
Old Jul 13, 2010 | 10:32 AM
QT1 5MT AE's Avatar
Gram Lights addict
yea sort of. IMO its a narrower wheel with a low offset for 4th gen. 9.5+ 40 is my cup of tea
Old Jul 13, 2010 | 10:41 AM
Flava_24/7's Avatar
Boosted Panda
9.5 on the front?
To me, it looks like the 9" is already out past the fender and the tires have to be strached a bit to fit under.
I dont want anything to poke out, just flush.
Old Jul 13, 2010 | 10:55 AM
QT1 5MT AE's Avatar
Gram Lights addict
9.5 ~+42 is flush flush
Old Jul 13, 2010 | 11:13 AM
Flava_24/7's Avatar
Boosted Panda
Hmm, that would be interstingto see. But what tire size? Woud have to be larger then a 235 right? Or else be stretched?
Old Jul 13, 2010 | 11:31 AM
QT1 5MT AE's Avatar
Gram Lights addict
no bigger than 245 235 is a slight strech on 9.5
9.5 10.5 is money on 4th gen.... by far the best with the right offset
Old Jul 13, 2010 | 11:43 AM
MROTH's Avatar
im runnin 19x8.5 +35 offset with a 245/35... same thing in the rear with a 15mm spacer....
about to run a 225/40 when i throw the coilovers on...
Old Jul 13, 2010 | 11:48 AM
Flava_24/7's Avatar
Boosted Panda
Those look pefect.. however I will have to use 235/40's since mine are still about 85% new.
Old Jul 13, 2010 | 11:54 AM
MROTH's Avatar
im honestly still debating between tire sizes once i install the coilovers....i want to keep the rear spacers on for fitment but i gotta get a less bulky tire on there....
Old Jul 14, 2010 | 09:01 AM
Flava_24/7's Avatar
Boosted Panda
18x8.5 +32?
the +35 looks great, will the +32 really be that much of a difference?
Old Jul 14, 2010 | 09:37 AM
QT1 5MT AE's Avatar
Gram Lights addict
it would poke 1-2mm.. nothing camber couldnt fix
Old Jul 14, 2010 | 12:55 PM
Crusher103's Avatar
u might have to run alittle bit of a stretch and a 25mm offset on an x8.5 to get the look u want.
Old Jul 14, 2010 | 01:40 PM
QT1 5MT AE's Avatar
Gram Lights addict
^^^ lol wuttttttttttt?
Old Jul 14, 2010 | 02:10 PM
Flava_24/7's Avatar
Boosted Panda
Hmmmm, Im wondering if 2mm will even be an issue, but I have Tein Basics and you cannot adjust the Camber with them. I wish I could freakin see it before making my decision. Its getting hard to find wheels I like in a good fitment.
Thanks for all your help!
8.5 with a 25mm seems to be too wide for the fronts based on what Ive seen so far.
Old Jul 14, 2010 | 02:33 PM
QT1 5MT AE's Avatar
Gram Lights addict
if by issue, you mean rubbing then you should get away with a 235 on a mild drop...... I would still suggest 8.5 +35 with a 235
to sum it up for you, I would NOT go for a 18x8.5 +30 upfront.
I dont like this fitment for 3 reasons
1) decent sized width but too low of an offset (cant run decent width tire and a decent drop)
2) requires stretch to be 100% rub free ( gotta step down to 205 for a real nice strech. 215 or 225 is more suited but still def not something you want to do with a boosted max, not to mention the overall diameter will be off unless you step up to 45, which will greatly limit tire selection)
3) contact area with ground is farther out compared to a 35 or even a +40. harsher on suspension.
4) simply put, ALL IT IS is narrow wheels pushed out. in other words, flush fitment with the fender while sacrificing everything else.
this goes back to why i said to go with a 9.5" with a ~+42....... Not only you will have perfect flushness, you get to run a nice width tire(245) while having a mild stretch that will allow you to drop the car a good amount, greatly improve handling, maintain a tire width centerd with the wheel well AND avoid having a huge gap between the two rims that looks FUGLY from the front.
if you dont care about looks, ENKEI RPF1 is the perfect wheel for you. great width and offset selection, great prices, qualitty and weight. heck, its argueably nice looking too.
just my last two cents.
Old Jul 14, 2010 | 03:55 PM
Flava_24/7's Avatar
Boosted Panda
Currently Im running 18x 7.5 +44 wheels, these are narrow, but as you mentione pullled in under front of the car.
Im not ditching the 235's though, they are almost new.
Would you have pics of this setup from the top and front of the car?
MplsMadMan
Sep 11, 2015 07:54 AM
Str8ridin
Mar 27, 2003 04:48 PM
TSW
Mar 23, 2003 08:28 PM
EZEMaxima
Dec 29, 2002 01:33 PM
TSW
Dec 13, 2002 10:57 AM
