BEST Struts...and yes i searched.....
I am looking to see what the best struts are for a 3rd Gen Maxima. My struts are shot and i want to replace them with something good. I do not want a bone crunching ride, but i need my Max to handle VERY good. I'm tried of the floaty ride of a GXE, so i want to know which strut will give me great handling (car will see track time) and also a "decent" ride.
Re: BEST Struts...and yes i searched.....
KYB
Tokicos
Koni
you didn't search hard enough.
Re: Re: BEST Struts...and yes i searched.....
Originally posted by DanNY
Low to high in $...
KYB
Tokicos
Koni
Low to high in $...
KYB
Tokicos
Koni
Re: Re: Re: BEST Struts...and yes i searched.....
not worried about the money really, i'll spend to make sure things are done right, but you're saying the Konis are better than the the tokicos?
Re: Re: Re: Re: Re: BEST Struts...and yes i searched.....
Originally posted by Neice Anne
Aren't Konis the best handling-wise too? Well to Obsidian yes get Konis if money ain't a thang
LOL, i wouldn't say money ain't a thang, but i have a friend who can get me hookups on parts...
Re: So don't pick Kyb Agx?
I noticed that no one recommended the kyb agx struts. Why not? Are they that bad, or are the koni's just that much better?
Struts
Konis are second to none, and barring failure which some have reported (warranty) they will not wear out like Tokicos will. My Toks, with a stretch, lasted 40K miles. Konis should last the life of your car.
John
John
struts
the konis fronts are not direct bolt ups like the other 2. the old fronts have to be customed to fit the inserts in. also chances are the koni's may be harder to get ahold of. it seems like every time i check with shox.com, they are backordered from holland.
Originally posted by Maximum5spd
Whatever you do DO NOT GET TOKICO, I had them for less the 15k, they are already warned out and make funny noises. Konis are awesome, theyre lil expensive, but trust me its worth the money.
Well i still have those tokicos in the front and konis in the back
i just was wondering if it was a good idea to have diferent springs in front than in back. i have already ordered the koni struts and i have a friend who has a back set of eibach's but they only lower it about 1.25 on the stock struts which still looks good but i would like the front lower. is that a bad idea?
The only thing is it might look a bit off kilter with the front slightly higher than the rear. Some of our cars do this already I think (called "saggy @ss syndrome" or something), due to sagging springs. But if you don't mind the look, then I think it'd be alright.
I have another question about struts, this may be stupid though but bear with me, do i ned to replace all 4 at one time? Could i replace the front and then do the rear later? Or would it be better to just replace all 4 at the same time?
