need recommendation on door lub
white lithium grease works great does not attract dirt clean with pb let it dry apply then wipe extra off
http://www.ehow.com/how_2083717_use-...um-grease.html
something like this is fine:
http://www.amazon.com/gp/product/B00...7R5DCZADB006DV
white lithium would be a good choice. What you learn over time is that things like PB Blaster and WD40 are not lubricating oils. They are a bunch of chemicals for penetrating into tight spots and getting them free. You should always use oil, grease or whatever is appropriate after you free something up with PB Blaster or WD70.
I agree that WD-40 and PB-Blaster aren't good lubricants.
Good luck getting any white lithium grease into the hinges where it is needed. In my experience it only makes a mess around the problem, but doesn't penetrate to where it is needed.
I find that a light creeping oil works for hinges. Put a drop or two where gravity plus the oil's attraction to metal will get it into the hinge.
I generally save my used motor oil, and if you don't mind a bit of clean up, it works great to keep the hinges oiled. Plus it's free.
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
