are se's supposed to shift like this:
Old Aug 17, 2010 | 12:03 PM
1992maximase30's Avatar
ok. i got tired of the going into neutral ****. so i replaced the trans.
i got mine out of a 97 se.
the fluid was red.
no burnt smell.
no particles or anything to that nature.
so the transmission that i got before was from a gxe.
here's the "problem".
at light throttle i say 10-15%.
the car will not shift till you get to 20mph.
20% or more it shifts fine.
no slip's, no flaring.
though the shifts could be a little firmer.
though love the fact that it shifts at the redline at wot.
any idea's
Old Aug 17, 2010 | 05:05 PM
Trini Boom's Avatar
the fluid was red.
no burnt smell.
any idea's
Hmmm...this is just a ballpark check but I would check the TPS to see if its adjustec correctly along with the IACV. If those check out, I would look at the drop resistor as another check. Try pulling any tranny codes to see if it has any stored.
Old Aug 17, 2010 | 05:40 PM
no tranny codes.
i did adjust the tps.
weird thing was with the old tranny every once and a while i would get the flashin od light.
and my codes would be tps and line pressure solenoid.
i could check it or adjust it for ****s and giggles.
drop resistor i might just switch out another 1 to raise the pressure a little.
and it does seem like a tps fault.
cause my friends cavaleir shifts the same way except with mine if the throttle was opened 25% or more it shifts ok.
also to piont out it does take a little bit longer when the trans is cold.
also i added a stacked cooler plate tranny cooler.
HOKUSMAX
Nov 13, 2017 04:34 AM
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
220k+ A32
25
Oct 3, 2015 09:09 PM
