Found an awesome spot to mount a gps antenna
Old Aug 21, 2010 | 10:48 PM
jgilbs's Avatar
Installed a pioneer avid-x920bt hu with built-in gps. After some thinking, found a great spot to mount the antenna. Pulled out the clock(I have a 5th gen), and the little "puck" fit PERFECTLY inside the enclosure
. Easy to fish wires to the hu, has a great view of the sky, and is completely hidden. Pics to come
Old Aug 22, 2010 | 06:14 AM
ICEMAN76's Avatar
Do you still have a clock besides the h/u's clock?
Old Aug 22, 2010 | 10:42 AM
jgilbs's Avatar
Uploaded with ImageShack.us
as you can see, it is tucked right above the clock module (this is the clock enclosure turned upside down), so yes, you retain the stock clock. When ut back together, it looks completely stock
Old Aug 22, 2010 | 04:37 PM
Andrew's Avatar
Thanks man! Great idea. When I do mine, i'll do the same =)
Old Aug 22, 2010 | 06:19 PM
ICEMAN76's Avatar
Nice!! I think I'm gonna try it too.
Old Aug 22, 2010 | 07:35 PM
BOOTZ's Avatar
Do you get reception with it there?
Old Aug 23, 2010 | 06:13 AM
mendon99's Avatar
tastey wheat
most people just stick them right on top of the nav unit. provided there is NO metal above the antenna, it will work anywhere..
Old Aug 23, 2010 | 09:03 AM
jgilbs's Avatar
That was what I had tried first, unfortunately, the 5th gen has a lot o metal in that area, and I got NO signal. I had it sit on my dash, and it saw 11 satellites, so I put it in the clock and compared, and sure enough I also had 11 satellites
Old Sep 5, 2010 | 01:59 PM
djfrestyl's Avatar
Suspension Yoda
Nice idea. I've installed it on a ton of 5th gens on top of the HU itself, without issue.
Old Sep 7, 2010 | 10:48 AM
MysticCBR's Avatar
i popped my clock off and mounted it right in front of that on the metal pad they come with ...then snaped clock back down after "notching it " worked mint ...i have a pic in my classified thread ill post up later at work
Old Sep 7, 2010 | 10:53 AM
BOOTZ's Avatar
Huh!
Didn't realize they could receive signal through surfaces, excluding metal I guess.
I'll have to try this on future installs!
Old Sep 7, 2010 | 04:42 PM
mendon99's Avatar
tastey wheat
Originally Posted by BOOTZ
Huh!
yep. Don't try this with sirius or xm antennas however... they MUST be outside or it will cut in and out frequently
Old Sep 7, 2010 | 09:19 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Yup, did several dozen right on top of the radio with full signal. Never an issue. Then again I stay away from Pioneers.
Old Sep 7, 2010 | 09:20 PM
Pearl96Max's Avatar
Hogwash ! ALL of my cars and the majority of my clients are all inside the dash. No issues.
Well, with exception to some Porsches and Benzs.
Old Sep 8, 2010 | 04:09 AM
mendon99's Avatar
tastey wheat
i move them outside of custy's cars all the time and it solves their reception issues..
wyobbagy
Jan 3, 2023 12:03 PM
DJLAX152
May 4, 2021 11:46 AM
DBear
Sep 14, 2015 08:33 PM
spidgeon
Sep 9, 2015 03:36 PM
Violator
Sep 9, 2015 10:14 AM
