Found an awesome spot to mount a gps antenna
Installed a pioneer avid-x920bt hu with built-in gps. After some thinking, found a great spot to mount the antenna. Pulled out the clock(I have a 5th gen), and the little "puck" fit PERFECTLY inside the enclosure
. Easy to fish wires to the hu, has a great view of the sky, and is completely hidden. Pics to come
Uploaded with ImageShack.us
as you can see, it is tucked right above the clock module (this is the clock enclosure turned upside down), so yes, you retain the stock clock. When ut back together, it looks completely stock
That was what I had tried first, unfortunately, the 5th gen has a lot o metal in that area, and I got NO signal. I had it sit on my dash, and it saw 11 satellites, so I put it in the clock and compared, and sure enough I also had 11 satellites
i popped my clock off and mounted it right in front of that on the metal pad they come with ...then snaped clock back down after "notching it " worked mint ...i have a pic in my classified thread ill post up later at work
Violator
09-09-2015 11:14 AM
