what is anti-sieze???
Old Dec 16, 2001 | 09:18 AM
mb1's Avatar
mb1
I'm trying to change my sparkplugs. Will WD-40 work?
Old Dec 16, 2001 | 09:19 AM
Sprint's Avatar
Re: what is anti-sieze???
what exactly is the problem? you can't loosen the spark plugs?
Old Dec 16, 2001 | 09:21 AM
mb1's Avatar
mb1
The instructions say to "Coat the threads of each spark plug with anti-seize".
Old Dec 16, 2001 | 09:24 AM
Sprint's Avatar
i change my plugs almost every 2 weeks.. you dont' need to put any anti-seize compound on the plugs.. just tighten them up.. when the rachett gets tight.. then do a 1/4 turn with the rachett don't over tighten.. don't leave them loose..
Old Dec 16, 2001 | 09:28 AM
mb1's Avatar
mb1
Thanks, but my new plugs will last another 60k, so thats like five years, I want to do it right. So you replace yours every two weeks with the expensive NGK plugs???
Old Dec 16, 2001 | 09:36 AM
Sprint's Avatar
well NGK Plugs cost me $6.50 so its ok.. i am running NOS so i am going back and forth between plugs.. often.. i am going to stick with these now .. the colder ones.. and stop being silly i guess i will just have to suffer with the decrease in peformance NA with colder plugs..
you don't need anti-seize compound.. no matter how long you are going to have them in there..
Old Dec 16, 2001 | 10:40 AM
nizmolee's Avatar
defintion
Anti- against Seize- to move,hold,stuck,...
Old Dec 16, 2001 | 01:18 PM
bmfjeep's Avatar
Anti-seize products are designed to provide an insulating layer between metals so that dismantling and routine maintenance are free from breakage of fused parts. This problem is especially onerous on threads. At less than $2.00 for a tube it really makes anything with threads easily removeable and will prevent the threads from gauling.
Dallas
WarpSpeed Performance
Old Dec 16, 2001 | 04:24 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
ya doug i would definelty use some especialy since we have aluminum heads.
Old Dec 16, 2001 | 04:29 PM
Sprint's Avatar
no
Old Dec 16, 2001 | 04:37 PM
shane's Avatar
Can this be used on lug nuts right
Old Dec 16, 2001 | 05:07 PM
yup you can use it on just about any metal to metal connection. i use it liberally on anything i take apart.
Old Dec 16, 2001 | 05:14 PM
Sprint's Avatar
aha.. the secret to FrankenCar
Old Dec 16, 2001 | 05:17 PM
i don't know how but when i saw the notification thread with your name on it i KNEW this was gonna be in here. grrrr
Old Dec 16, 2001 | 05:20 PM
Sprint's Avatar
Old Dec 16, 2001 | 05:24 PM
Old Dec 16, 2001 | 07:03 PM
Albertt's Avatar
It's usually a molybdenum based grease >>
Go to your local autoparts store and ask for it. It's usually a silvery grease. Use it on lugnuts, spark plug thread (but carefully) and you can even coat the back of your brake rotors before you install them to prevent the rotors from freezing on the hubs (learned that from DanNY).
Old Dec 16, 2001 | 07:24 PM
Kyle7475's Avatar
hey sprint, why would you change your sparkplugs so often?
Old Dec 16, 2001 | 08:26 PM
mb1's Avatar
mb1
he alerady explained earlier.
big-daddy-j-dawg
Jan 15, 2013 02:41 PM
95maxrider
35
Mar 16, 2012 05:58 AM
03VQMAX
Nov 20, 2011 07:18 AM
Kevin
Jul 8, 2002 09:43 AM
