Has anyone tryed rtv silicone on intake
Just wondering I think I need a new intake manifold gasket and instead of spending like $100 plus for one from nissan I was wondering if anyone tryed silicone? Can it be done? The stuff is strong as hell so if it can be done I will use it.
$100 plus on a intake manifold gasket? You obviously are shopping at the wrong dealer...one can be had for around $20. A tube of RTV silicone sealant is around $6. The RTV sealant will be a messy, one-time, job. The intake gaskets can be reused.
Wait, are you talking about the lower intake manifold gaskets or upper? The lower are a little more expensive at about $30 a piece. Dave Burnette at South Point Nissan can get you a discount though.
I really wouldn't recommend the RTV on the lower intake. You don't want to end up getting any residual RTV selant into the valves.
I did the same job about 15 months ago with the dealer intake gaskets,It was the lower intake and it lasted til now.So I was wondering if rtv would be a better hold.Foodmanry you say the intake gaskets can be reused? Maybe I will try resealing using the old ones with atv.Yes I know it should have lasted longer.Thank you guys.
I hardly think you have an intake leak at that part. It could be a leak upstream from the lower intake manifold, but I doubt it.
You may have a problem with the pre-cat you installed. Which one did you go with? Did you do a search? As I have perused different threads in here it seems there are some aftermarket pre-cats which do have leaking issues.
Yeah, it's the stuff you're supposed to use with a spacers install, so I'd assume it'd work fine... The only problem is that you have to scrape it off (not really all that easy) and re-apply it if you ever remove your IM again.
ballerchris510
Sep 10, 2015 09:35 PM
Maxima30
Sep 7, 2015 06:13 PM
lux97Max
Sep 4, 2015 05:42 PM
