View Poll Results: Would you rock 5mm spacers with no extended studs?
Yes
68.18%
No
31.82%
Voters: 22. You may not vote on this poll
...still debating weither to just do it right with extended studs, hahah hence if i need studs I mind as well just go for 10mm... which may actually change sumthing.. ..but then it defeats my 20mm in the back more than having the 5mms
I rock 5mm in front and 15mm in rear in the summer for the summer wheels (17x8+45, 235-45-17 or, depending on my mood, 18x8.5 +33, 245-40-18) In the winter I rock out with OEM 17's using 10mm in front and 15 mm in rear (235-45-17
Why not just get H&R's? Even the 5's come w/ longer studs.
Both my summer wheels/tires rub w/ 10's in front, so keep that in mind if you do go w/ 10's. What's your current width/offset/tire now in front?
summer -18x7.5 35mm and tires are 225/40/R18
winter - 17x7.0 40mm and tires are 215/55/R17(all stock)
interesting fact with the 10s.. when you ride with the 5s I take it you use the extended studs you use for your 10s?
i take you do not rock any of them with out extended studs then...
I got H&R 20mm rear, 5mm front.
I used the slightly longer studs for the front because it only took 1 minute to knock the old ones out and put new on.
Now I gotta roll the rear fenders cause I have slight rubbing if I hit a good sized bump.
5mm I would notice. no one else in the world would though, maybe on here via pics but thats it. to give you another idea some people dont even notice the 20mm in the back.
5mm spacers in the image below.
I'm all about doing mods where I'm the only one who can appreciate it (engine bling, for example). But IDK... 5mm is a pretty subtle mod. And these spacers aren't exactly bought for pennies, either.
[IMG]http://www.streetbeatcustoms.com/productImages_thumbBIG/a58b23b7_4514.jpeg/IMG]
anything with studs is over $56, brand name is over $62
http://i196.photobucket.com/albums/a...1/DSCF2073.jpg
heres a pic where I think you could recognize the 5mm or 13/64" or 3/16"
You should see me with my winter steelies on. It's like the opposite of spacers. We'll call them "suckers".
Any day now, too, damn it.
This is kind of a fun animated gif on before/after spacers...
...with the following comment on the retailer's website:
"NOTICE: You can install the 3mm spacers onto your car with factory wheel studs, but its recommended for safety you install longer wheel studs. 5mm and 8mm wheel studs CANNOT BE USED with factory wheel studs as there is not enough thread to safely use these. Youll HAVE TO purchase longer wheel studs to use with these yourself."
^^and did u use extended studs for the 5mm spacers up front ??
I would like to mention that because of this thread and the way the poll is going I am most likely going to rock 5mm spacers with no extended studs.
Thanks all.
Thanks all.
http://www.andysautosport.com/nissan...i00000748.html
here's an example i have saved for 5mm studs
u r crazy don't do that. and go with aftermarket all u need to know is 14mm Knurl and your spacer size determines the lengths u need
Thanks Autozone won't have them?
doctorpullit
Apr 23, 2017 05:35 AM
