Anybody hook up an aftermarket fuel pressure regulator??
I got this aftermarket fuel pressure regulator with the 255lph fuel pump I got and was thinking bout hooking it up. I just wanted to see what other members had if anything. It's mostly just for looks right now as the fuel pump is mostly for the near future.
This is only pic I have. I can get better ones if needed. Mounted mine on the fire wall with custom bracket.
This is way expensive can get them cheaper. Or just make one.
http://cgi.ebay.com/ebaymotors/Fuel-...Q5fAccessories
Yeah you can barely see it but thanks, I'll probably just rigg something up on a motivated day. Right now I'm ****in' around with a short that keeps popping my fuel pump fuse but after I solve/repair this I'm planning on hooking the fuel pressure regulator up, mostly for looks right now but good to have for future plans.
Yeah I did on my 90 VG....Do Not waste your money on the adjustable Nismo....This is from Performance Products.....3 port, you only need to use 2 of them...the Nismo will cause erratic idle due to it's small spring pressure at settings under 60 psi at idle which is way too high!
Forge277
Jun 13, 2016 09:26 PM
