Wheel Bearing o.0
i replaced the right one with a new bearing (thats where the vibration/humming was coming from) now the noise is reduced a little and i think im gonna have to do the left one now. i noticed the axle nut came loose and the wheel was wobbling when i jacked it up. if that doesnt fix it axles are next. not a big fan of throwing parts on but i cant take the noise/humming anymore
it almost feels like its coming from the middle. it cant be the engine or trans. i eliminated the possibility of that. so from the axles to the wheels is where the problem should be
yea it was a pain. i torched the lower ball joint bolt and used all types of impact guns. (well only 2 but 300ftlbs of torque wont do it "snap on cordles impact") (USE SOMETHING WITH BIG LEVERAGE) then the wheel speed sensor broke cuz it wouldnt come out. (i had to break it to get the knuckle to a place where i can work on it easier. (THAT WAS THE HARD PART) as far as taking out the bearing and putting the other one in was pretty easy
When everything is tightened up down there, which way does the wheel wobble?
If it wobbles like this, they bearing is probably shot:
http://www.youtube.com/watch?v=5ybpu...eature=channel
If it wobbles like this, the tie rod is probably shot (fast foward to 1:45):
http://www.youtube.com/watch?v=hnNb3...eature=channel
well that thing wobbled 360 degrees lol. the axle nut walked off
londonflu
40
Sep 25, 2015 09:11 AM
