Removing fuel injector wires?
Well, I'm trying to remove the plugs that plug into the injectors so I can get the main harness out of the way. I know that there is that metal clip, but I can't get it to slide out. Any help would be greatly appreciated. Thanks!
Hmm VG? If there is a small metal square clip that holds them in, you have to use a reall small screwdriver or pick.
You gently pry one end of the clip at the end and push it out. At the same time, pull the connector out a little on that side. This should prevent the clip of "snapping" back in. then do the same on the other side. The connector should come right out. Becarefull not to pry too much or you might break the clip holder on the back of the connector.
The Frye
Sep 2, 2021 11:03 AM
