I broke my Max doing plugs and wires.. WTF? need help.
Lately my Max has been idling a little rough and I figured it's time for new plugs and wires so I get it all done earlier today along with a much needed oil change. But somehow I ****ed up and I broke my car. Won't even start now. If it does it runs rough, stutters and dies pretty quick. I did new:
Plugs,
Wires,
Distributor Cap
Rotor
Oil change
What could I have ****ed up?
I checked the firing order like 5 times all good per manual for VG30E engine (135 left to right firewall side, 246 radiator side left to right) and I even marked the plugs with tape on the manifold before I started AND took pics with my phone.
Took a couple plugs out and checked the gap. All good.
Made sure the plugs connectors were secure.
Put the old distributor cap and rotor on there just in case I got a faulty part. No different.
Only thing I haven't done is try going back to the old wires.
I even put a couple more gallons of gas in just in case it was a fuel problem from being up on the jack or some unlikely crap. I had a 1/4 tank in to start anyway.
WTF?
Plugs,
Wires,
Distributor Cap
Rotor
Oil change
WTF?
From: Long Beach, CA is where i live. Queens NYC is always home.
sounds like a misfire.... trace back your steps. I suggest you start w/ putting back your old cap and rotor. Could be a defective part somewhere. There is practically no way you can mess up firing order. The cap is marked to tell u where to go. Just remember bank 1 is ALWAYS on the firewall side in these cars. Do a spark check. A defective wire or plug can do this too. Happened to me w/ my VG car. Had a defective NGK wire
Hopefully you lined up the notches on the distributor before putting it back in, also the rotor cap will need to be adjusted to get it right (use a timing light for this). Recheck all electrical connectors, vacuum lines and please tell me you had the battery disconnected whilst doing the work.
The distributor rotor only goes on one way and once the retaining screw is in there's zero play so I don't see how I could have put it on incorrectly. Same with the cap. As well I made sure to not move the distributor rotorshaft which is pretty near impossible to do anyway. How could I have put the rotor on wrong? I don't see how it's possible. I backtracked and put all the old parts on except forthe cap and rotor and she cranked and ran for a few minutes and conked out. The engine turns over fine and will occasionally catch and then conk out again pretty quick.
