Key fob window roll UP feature ???
as most of you know when you hold the unlock button on your keyfob for more than 3 seconds your windows roll down (if you didnt know, youre welcome
) and the only way to roll them up outside the car is by inserting the key in the door and holding toward the lock direction for a few sec's.....
my question is: can you add a relay/auxiliary device to roll UP the windows from the keyfob? Anyone done it? or even thought of it?
NGK
) and the only way to roll them up outside the car is by inserting the key in the door and holding toward the lock direction for a few sec's.....my question is: can you add a relay/auxiliary device to roll UP the windows from the keyfob? Anyone done it? or even thought of it?
NGK
Im pretty sure it will, try it. Also, found a link from another forum from one from KP -
http://www.kptechnologies.com/products.php#/17
NGK
NGK
yea probably why. It works with the factory keyfob (remote) however, if you bought a good aftermarket remote start/alarm like DEI then you should be able to add an auxiliary up/down feature pretty easily
On my '02 I35 when I try this it starts to roll up but then stops. It acts as if something is blocking the window (like the fail-safe for the auto-up feature).
Any ideas why this may be happening? Nothing is blocking its path when I try this.
