AUTO power window not working on driver's side
I tried resetting,
http://bestpcreviews.com/car/208-res...initi-i35.html
But that didn't help.
AUTO function still not working on driver's side, any ideas?
Do you hear any sort of noise (either mechanical like it's hitting something, or electronic like a relay opening) when it stops?
If while the window is lowered as far as it will go, when you push the "down" switch again, does it ignore you as if the window was all the way down, or does the motor make a straining noise as if it was trying to bring it down a little further?
Wait...
I just re-read the original question.
Does the switch still work manually, just the "auto" function is busted?
All and all it can only be a handful of things. The power windows are not that complex. It's either a switch or a regulator/ motor. Or a power ground issue. Maybe, the track?? Check everything.
Thanks, I decided that I will disconnect the switch and then try to lower the windows with keyfob. If my window will not go down AT ALL, then it will be switch for sure. If it will go down just like it did with switch connected, then I'll have to look for another solution.
I noticed that the switch inside was little dirty like someone worked on it, also one of the connectors to the switch (door locks) was kinda broken and had zip tide attached to it to keep it together.
sounds like the switch is sensing resistance and shutting off the motor. I have seen this before on other Nissan with auto up/down. I was able to relearn the closed/open position and it started to work again just like the auto sunroof switch on the 5.5gens. I forget the relearn procedure but it's definitely not what you have linked above. I didn't have to take anything apart to perform the relearn. The instructions might be in the owners manual.
kingw323
20
Oct 21, 2015 08:36 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
KGMtech
Aug 18, 2015 09:21 AM
erniel
Aug 8, 2015 09:32 AM
