Perplexing question regarding headlights..only low-beam is not working
My driver side headlight is not working. Well it is, but just the low-beam doesn't work. The high beam and DRL work fine.
What could be wrong?
Originally posted by theblue
swap your headlights and see if its still messed up on the drivers side. this will tell you if you bulb is the problem
SEguy: If the low-beam filament was dead, then wouldn't my DRL not work either? But it does work?
Re: Re: Perplexing question regarding headlights..only low-beam is not working
Originally posted by yo_its_ok
yer fuse for low beam...or yer headlamp relay is cooked.
UPDATE: I replaced the Eurolite bulb with the original Nissan bulb that came with the car and it worked fine. So it was the bulb after all. Its wierd that only the low-beam would not work while the DRL does. Does the DRL use a different bulb? It doesn't seem like it.
Anyway, if any of you TO guys see a Maxima that has one hyperwhite bulb and one stock bulb, that would be me.
ah2002
Mar 9, 2016 01:42 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
doobadoo
Aug 15, 2015 06:43 PM
MikesChevelle
Aug 10, 2015 11:21 AM
