Consult-II Owners...
Old Aug 23, 2011 | 05:25 PM
shadyonedeath's Avatar
Requesting someone be generous enough to workout a deal to let me use their Consult-II to fix my idle problem. (Don't want to give dealer 100$ for 10 min digital inspection). We'll work out shipping/insurance/deposit...whatever it takes.
Post here if you own one, very few do.
Old Aug 28, 2011 | 10:58 AM
Really need this guys...will compensate. Just need to reset my ECU's idle/check timing
Old Aug 28, 2011 | 11:15 AM
036mtmax's Avatar
You can also use Cipher,I bumped my timing with it
Old Aug 28, 2011 | 03:58 PM
Can you adjust the base idle via ECU?
Old Aug 28, 2011 | 09:15 PM
036mtmax's Avatar
Yep, Copy and pasted this from uprev's website,It's worth the money IMO,Used via laptop with obd to usb cable,Also can use as a scan tool to check or clear codes
  • Target Idle RPM
  • +/- 2 degree static timing adjustment
  • Cylinder power testing
  • Clear Learned Fuel settings
  • Manual control of BCM functions, ie. Windows UP/Down, Activate Locks, Wipers, Lamps, etc.
  • Fuel Pressure purge
  • Ethanol Adjustments (if vehicle is equipped)
  • Coolant Test
  • Engine Speed - RPM
  • Throttle Position Sensor
  • Vehicle Speed
  • MAF Sensor
  • Calculated Load Value
  • Oxygen Sensor
  • Ignition Timing
  • Accelerator Position
  • Wide Band A/F Voltage (equipped vehicles)
  • Coolant Temperature
Old Aug 29, 2011 | 07:21 AM
and its proven to work on 99 ECU? Remember, we have NATS.
Old Aug 29, 2011 | 07:50 AM
NmexMAX's Avatar
dot dot dot ...
Pretty sure it wont work on the 4th gen.
Old Aug 29, 2011 | 09:17 AM
aackshun's Avatar
Yeah aw hale nawwww, UpRev only works on 2004+ nissans.
Old Aug 29, 2011 | 09:22 AM
NmexMAX's Avatar
dot dot dot ...
02+. Works on my 03.
Cipher works on 02+
OSIRUS 04+
Old Aug 30, 2011 | 03:18 PM
made in china's Avatar
A little OT: http://www.righttorepair.org/about/faq.aspx
It's legislation that will require auto manufacturers to make "proprietary" tools, software and diagnostics available to the aftermarket. If this bill passes, you'll be able to get a Consult-II type tool off eBay for the same price as any GST.
I need a Consult-II for my 3.5 swap, but the dealer won't assist me and the used Consult-II are on eBay for over $4K.
Old Aug 30, 2011 | 03:21 PM
NmexMAX's Avatar
dot dot dot ...
Why not get a Cipher? 200$ with a whole helluvalot of latitude.
Old Aug 30, 2011 | 03:31 PM
Does it access BCM, TCM and CAN data? I need to access everything in both my Maxima and Titan, they both have little "issues" with non-engine related things.
edit: OK I see it does BCM, how about TCM?
Old Aug 30, 2011 | 03:47 PM
NmexMAX's Avatar
dot dot dot ...
Do you frequent the Titan boards? I do and the BCM, TCM works with the Titan ECU as does the CAN.
The BCM has limited functionality with the A33B ECU, and only allows ABS codes to be read. TCM & CAN data also work, but only the AT Maxima uses the CAN lines in the A33B, and there are only 2 of them.
Cipher uses the Consult interface on the A33B ECU.
Old Sep 1, 2011 | 11:11 PM
bump...save my maxima.
Old Sep 2, 2011 | 05:31 AM
Shift_Max's Avatar
Cipher is a great tool especially considering the price. However it will not work on the 4th gen ecu.
But i still wish I had a consult-2. Dealers are stingy.
Old Sep 5, 2011 | 01:08 AM
ThurzNite's Avatar
Anybody got a link to where to buy consult?
Dr J
Old Sep 5, 2011 | 07:53 AM
Kevlo911's Avatar
Kevlo for President
I am confused what you need a consult for.
You want to check the timing at idle? An OBD scanner can do that. You can't edit a 4th gen ECU, if you bump the timing; that will be lost once the car is restarted.
As for the idle, just adjust from the IACV. Check the 4th gen forums on how to adjust the base idle.
Old Sep 5, 2011 | 10:00 AM
Dr J
They come up on eBay every so often for a min of $2K.
I'd wait for the "Right to Repair" legislation to pass. Soon we'll have access to all the data tools for every aspect that the OEM made available to dealers only.
Old Sep 5, 2011 | 10:49 AM
Kevlo911's Avatar
Kevlo for President
i use the 30 dolla consult on ebay with the ecutalk software to read the ecu's sensors.
Old Sep 5, 2011 | 11:38 AM
ThurzNite's Avatar
That's for Consult II? Ick, well, if we can get 10 people, $100 each, I'll fork over $ to buy one and set up a queue system.
Dr J
Old Sep 5, 2011 | 11:08 PM
Mr. Blue Sky's Avatar
geez, those consults are expensive. I guess I will have to wait till that legislation passes to affordably do what the consult does.
Old Sep 8, 2011 | 11:58 AM
I need it to reset or change my base idle. I've been posting about this for a while, basically my idle is way too high for no good reason other than the ECU chooses to keep the IACV wide open and allow too much air to bypass during idle. (1300 rpm with TPS disconnected, which is the idle relearn procedure. Supposed to be 550rpm)
I've gone through the check list of high idle symptoms and everything checks fine. Only thing I cannot check is the ECU. The consult will determine what's wrong at idle, and can change it right there if its electrical.
(Note: When I had my NATS keys reprogrammed, my 00vi was still raw. Something might have happened where they reset idle and change the settings. I'm guessing because he had trouble connecting to my ecu and was doing all sorts of crap. )
Old Sep 8, 2011 | 01:25 PM
njmaxseltd's Avatar
You cannot change the base idle speed or timing map on a 4th gen ECU.
The consult will do you no good.
Shadyone - Put the original manifold back on the car, make it completely stock once again. If the idle doesn't return to normal, you might have a ECU issue.
I still think something isn't right with your 00VI install. If you've got everything closed, (TB and IACV disconnected) the car should stall dead. If it doesn't, then your getting air into the intake track somewhere. This has nothing to do with the ECU.
Old Sep 8, 2011 | 01:59 PM
Clashez's Avatar
Consult II 25.99
http://www.gadgettown.com/Nissan-Dia...rt/large-image
Old Sep 8, 2011 | 03:32 PM
Originally Posted by Clashez
That link shows a Consult-I adapter that connects to the older 14 pin stand alone Consult diag connector.
Old Sep 10, 2011 | 08:41 PM
Not the idle, but I can change the timing, which is whats happening. Car idles so high that when everythings connected, it pulls the timing at idle to reach 750rpm.
And whats bad about it is that when in Drive, it the pulled timing causes it to idle low @ 590rpm and shakes the car.
Still no vacuum leaks. Reverting to stock is not a option at the time and will cost me 80$+ in supplies/gaskets.
Old Sep 11, 2011 | 06:36 AM
Kevlo911's Avatar
Kevlo for President
You cannot change the timing, once you turn off the car the ecu goes back to "stock" settings. W/E ecu timing changes you make in consult only last in that session of the ecu ie, when its on. Once its off those changes are lost.
Old Sep 11, 2011 | 11:12 AM
so the only purpose of the consult is data logging and programming keys?...
Old Sep 11, 2011 | 01:52 PM
Kevlo911's Avatar
Kevlo for President
yes for 4th gens. Other gens it can do much more. Our ecu's are very "basic"
Old Sep 11, 2011 | 08:46 PM
Then...thank you for saving me the trouble.
Old Sep 12, 2011 | 09:28 AM
ThurzNite's Avatar
How about an ecu piggy back to change timing?
Dr J
Old Sep 12, 2011 | 10:45 AM
Dr J
Would work but its be like putting a bandage rather than fixing the problem.
Old Sep 12, 2011 | 03:24 PM
ThurzNite's Avatar
Agreed. How else do u propose changing timing since consult's not gonna work? Do you think JWT could help you reflash?
Dr J
Old Sep 12, 2011 | 10:20 PM
Dr J
I just want to know why it's not closing the iacv. Like I said, it idles at 1300 with TPS disconnected and it's because the iacv stays wide open. I know bcos I plugged the iacv from it's mid box measured air source and it would idle at around 500 rpm. Heck even a new iacv from rock Auto had the same results!
Old Sep 13, 2011 | 01:21 AM
I am not following this. How is it that disconnecting the TPS is a method of troubleshooting the IACV? I think previously it was mentioned that if the throttle plate was closed completely, that the idle would be high if air was finding it's way in through other means, such as IACV. The TPS is just a input sensor for the ECU.
It seems that you are SURE the IACV isn't being closed by the ECU, right? But it closed previously? What mods or work have you done? Have you checked to see if the ECU is sending an output to the IACV? And that the ground circuit to the IACV is good? Oh I now I see you put the 00VI on your car? I'd definitely be checking all of your electrical connections. It seems you checked vacuum leaks. The ECU will prob throw codes for a sensor input that was wonky, but the ECU doesn't usually throw codes if an actuator isn't operating as that's an ECU output that isn't monitored.
Jeez I am all confused because I didn't see what kind of car you have and what mods you have done. But, if you do have a 1999, then the link to that $25 Consult-I tool that Clashez shared would be something worth looking in to. My 1997 Maxima had both the OBD connector and the 14 Pin Consult-I connector.Look here for more info: http://www.blazt.biz/blog/nissan/72/...sult-or-obdii/
The Consult-I should be able to give you more in-depth info on what your ECU is doing. I am not a Consult-I expert, but I did get to see a Consult-I used on my 1995 200SX many years ago, and it was able to show a lot more info than an OBD scanner can. You should be able to monitor whether or not the ECU is in control of the IACV, and if not, what may be the problem that causes the ECU to not close the IACV.
Old Sep 13, 2011 | 03:52 PM
You disconnect the TPS to perform the IACV relearn procedure. On a typical normal stock working maxima, with the tps disconnected, the cars idle should be around 550. (in other words, LOW). But this is not the case with mine. For me, it gets even Higher, up to 1300+ but never below 1300rpm no matter which way you adjust the idle adjustment screw on the IACV.
And the throttle body play is NOT supposed to be completely closed or so i've been told by members. It supposed to be slightly open to pass air, which is what the stop screw on the Throttle body is for.
Is this not standard FSM procedure? Tps disconnected = target idle should be 550. What am I supposed to assume is the problem when the idle wont drop from 1300 rpm and there are no vacuum leaks? (I've tested vacuum by plugging up the throttle body and pressurizing the intake manifold via a vacuum hose. The result was my engine is so sealed, the plug on the throttle body popped off. I even tested it with suction, and it held vacuum until vacuum was released.
Old Sep 14, 2011 | 12:30 AM
Check to see if you have a 14 pin Consult-I connector. You'll be able to use that $25 tool to diag your car.
Yayomax
56
Jun 15, 2018 09:40 PM
torontoboy
Nov 15, 2002 07:23 PM
yongjun
Feb 27, 2002 12:27 PM
