timing chain or ...?
Old Sep 13, 2011 | 03:45 PM
5150pa's Avatar
http://www.youtube.com/watch?v=dk3bA...e_gdata_player
Video i grabbed before work. Is this timing tensioner/guide or something more sinister
Old Sep 14, 2011 | 01:52 PM
L_U_D_I_AMaxima's Avatar
can't really tell by the video.... did you check the belt tensioner? how many miles?
Old Sep 14, 2011 | 04:02 PM
5150pa's Avatar
I sprayed the pulleys with wd40 and didnt hear it quiet down. I can grab another video. It'll be on my phone again. Probably crap audio again.
Old Sep 15, 2011 | 06:07 AM
it is very possible that it might be bearing on the belt tensioner... I had to replace mine a couple of months ago... it just got louder and louder every time I drove the car... I remember the tensioner was $20 from Autozone... with the lifetime warranty, not a big fen of their parts by the next morning I was taking on a 3000mile trip... As of now I have put about 7,000 miles on it and it is still quiet... To check that sucker you have to take it out, then spin it and then may be spin the alternator to see if the bearings inside make noise...
Old Sep 15, 2011 | 07:28 PM
5150pa's Avatar
Will do, Payday is tomorow and my oil looks like garbage. Big weekend coming.
Old Sep 16, 2011 | 09:54 AM
Comicus's Avatar
Sounds like your A/C compressor pulley. It will make the sound whether or not your A/C is turned on because the pulley is constantly tuning. Remove your belt and start the engine (but don't let it run for too long because your alternator isn't tuning and charging your battery) if the sound is gone it's most likely your culpret. Turn off your engine and turn the pulley by hand and see if it makes the noise. A cheap temporary fix is to buy a shorter belt and bypass the A/C pulley (I don't remember the size but it's in a thread somewhere on here). If this is the problem something has to be done soon because the pulley will sieze and the belt will snap and you will be on the side of the road.
My 2000 maxima made a similar noise at 170,000 miles and that was the problem. It's easy to replace yourself and I went ahead and replaced the Alternator while I was at it bercause you have to remove the A/C compressor to get to bolts that hold the alternator on.
Good Luck
Old Sep 16, 2011 | 10:14 AM
Comicus's Avatar
If it is indeed your problem the part # on the belt I used is 6PK0915 360K6. Basically a 36 inch belt.
mvm062
Nov 30, 2020 09:00 AM
maxinout93
Oct 27, 2015 01:29 PM
intimidator
Sep 5, 2015 07:23 PM
trungg86
Sep 4, 2015 04:58 AM
Balkins
Aug 12, 2015 06:39 AM
