Help No fluid in Clutch reservoir !
Old Oct 11, 2011 | 09:10 PM
maxdis1's Avatar
I went to take a drive this morning and my 01 max had almost a dead clutch pedal! I got the car in gear and was able to drive . Later after work I checked the clutch reservoir and there was no fluid in it.... Drove to Advance Auto and purchase Prestone Brake fluid , poured it in the reservoir and almost immediately the clutch pedal regained pressure . I am worried . Apparently no fluid seems to drop off the "Max mark" on the reservoir as of this evening .
How do I test to see if the Clutch Cylinder is leaking ,ect.
Kindly share your input.
Old Oct 11, 2011 | 09:12 PM
chrome91's Avatar
check your clutch slave cylinder, if its leaking you will feel loss of clutch pressure and will of course leak fluid. thats where i would start, if the slave cylinder is good see if the cylinder or lines are leaking
Old Oct 11, 2011 | 09:41 PM
maxdis1's Avatar
Thanks for your quick response. I also just found Motovate website and I am looking into the pics . I now know where to start looking and what to look for. I think it may be a line.
thanks again.
Old Oct 11, 2011 | 10:54 PM
QT1 5MT AE's Avatar
Gram Lights addict
had the same problem with my 01. check for leaks on clutch line. i had to replace mine
Old Oct 14, 2011 | 03:35 PM
kpgc10's Avatar
yeah usually in general slave cylinder fail causes those symptoms.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
Need help
23
Oct 2, 2015 08:56 AM
carlosvq30
Sep 26, 2015 09:44 AM
