HID's installed and problems
Old Oct 25, 2011 | 05:21 AM
Tee00Max's Avatar
I just recently installed a set of HID's in my headlights about a week ago and when I first installed them, I installed without using the relay harness and I noticed when the lights would come on, one would go out, I turn them off and back on and then the other one would go out and sometimes both of them would go off. So I figured that it was because I didnt have a relay harness, so this weekend I installed a relay harness and it seems to be doing the same thing. I can turn them on and off about 3 times or so and when then they become alright and will remain lit.
Does anyone else have this issue? Im using a local seller of HID kits and his kits are pretty good. Does the car have some type of failsafe that recognizes that the lights are aftermarket and it powers them down?
Old Oct 26, 2011 | 05:18 AM
Tee00Max's Avatar
Anyone???
Old Oct 26, 2011 | 06:32 AM
eesjunin's Avatar
did you use an additional ballast on top of the ballast that built in?
Old Oct 26, 2011 | 07:45 AM
Tee00Max's Avatar
I have a S package which does not come with HID's from factory.
Old Oct 26, 2011 | 08:54 AM
Make sure everythings connected well.
Old Oct 26, 2011 | 09:01 AM
Tee00Max's Avatar
Yea everything is connected good, I think its a voltage issue going on since the factory wattage is 65 and I have a 35W kit. My guess is that its kicking them off because their not getting enough voltage...
Old Oct 26, 2011 | 09:25 AM
Unless a warning light comes on off the dash then I doubt it. I've never seen a problem like that unless that happens.
Does the problem happen when the car is on, off or both?
Old Oct 26, 2011 | 09:51 AM
Ghozt's Avatar
if you have a voltmeter you can test the connections to see what voltage they're getting
Old Oct 26, 2011 | 10:14 AM
eesjunin's Avatar
I am not sure thats entirely true...i got 35w kit on my fogs..no problems
I would double check those ballasts...
also for sh&ts and giggles i woul take those ballasts and plug them into your fog light ports and see if you get the same problem if you do then its your ballast, if you dont then there is something else going on with that headlight wirring/voltage etc...
Old Oct 26, 2011 | 10:18 AM
Tee00Max's Avatar
Yeah I dont have HID's in my fogs right now but im just going to take my car to where i got the HID's from and let him look at it, glad I have a local HID spot....
Old Oct 26, 2011 | 10:25 AM
eesjunin's Avatar
i know...but you can just use the wiring for hid's and test you ballast with that bulb that you got for your headlights..
i bet you its the ballasts since one side is ok
Old Oct 26, 2011 | 10:43 AM
Tee00Max's Avatar
Well its actually both sides, one side would go out and then I turn them on and off and then the other side would go off and sometimes both of them would go off so its not favoring one side..
Old Oct 26, 2011 | 10:48 AM
Your ballasts and bulbs need to be tested.
Old Oct 26, 2011 | 10:51 AM
Tee00Max's Avatar
Yeah im roll over there prob when I get off work and see whats up with them...
Old Oct 26, 2011 | 12:41 PM
If they can't test em, you can always DIY test off your battery.
Old Oct 26, 2011 | 12:42 PM
Tee00Max's Avatar
Well there already running off my battery because I have a relay harness...
Old Oct 26, 2011 | 12:49 PM
I know that. I'm saying, remove the HIDs and use the big connectors that plug into the ballasts and their wires to tap the bulbs/ballasts directly to the battery.
Old Oct 26, 2011 | 01:19 PM
hamzer11's Avatar
It's simple. When the light is out, check the voltage at the stock harness before the aftermarket HID connector. Then just before the ballast, then after the ballast. You will figure out where the fault is.
Old Oct 27, 2011 | 11:42 AM
KillaKam's Avatar
IMO; you may have a defective ballast(s) out of the box as a first option or when you first installed them by not having a relay it may have damaged the ballast(s) so even with the relay now installed the damage is pretty much done.
The manufactures warranty should cover this issue.
Old Oct 27, 2011 | 11:46 AM
Tee00Max's Avatar
But I have been running HIDs for years now and have ran into every possible issue but this is a first. I will go by there today when I get off to see if I can just get a whole new kit.
Old Oct 27, 2011 | 05:42 PM
Mr. Blue Sky's Avatar
to see which ballast/bulb is the problem just switch the bulbs first from one side to the next, then do the same with the ballasts. If the problem follows the ballast or the bulb, you have found the component that is the issue.
Old Oct 27, 2011 | 07:13 PM
BBmaxi's Avatar
Its your ballasts and possibly hid bulbs, swap everything out for another set..its usually the ballast. Dont bother wasting your time testing this or that. I had flickering issues when i first put on aftermarket hid on my base S, i just swapped the balast and it fixed the problem.
Its most likely your ballast, change em
Old Oct 27, 2011 | 07:46 PM
Tee00Max's Avatar
Whats the odds of me getting 2 defective ballasts??? Both sides are cutting off, there not flickering, they will stay on for a little bit and go off. It doesnt seem like a ballast problem but I am going to swap them hopefully tomorrow.
Old Oct 27, 2011 | 08:28 PM
unlikely, but not impossible to get two bad ballasts/bulbs. Switch them out if you can.
Old Oct 27, 2011 | 10:14 PM
Kmoney's Avatar
I think u have a bad bulb. I once had That problem. I would turn on my fogs and the right side will come on then a minute later shut off so I turn them off n back on but still get the same problem. So I check n found out my ballast was bad
Old Oct 28, 2011 | 08:39 AM
BBmaxi's Avatar
very high, the quality control on these balasts are horrible.
maybe 10-15 pct of them are bad
Old Oct 28, 2011 | 08:49 PM
minsbang's Avatar
I installed HIDs on my '09 S and either one or both would not turn on during the first try. On the second try, it always comes on. I've been dealing with it for the past few months since the install itself was a pain in the rear. I hope I don't have to deal with it again where I have to replace one or both. For now, I'll deal with having to turn the headlights on and off, and back on few times.
Off Topic: You own an S model and have the side view mirrors with the turn signals? If so, did you purchase them seperately and install them yourself?
Old Nov 1, 2011 | 07:06 PM
Tee00Max's Avatar
Must have been a bad kit or something because I ordered a pair from Hidextra on their Halloween sale and installed today and it has not been one flicker! good quality kit, check them out!
Old Dec 5, 2011 | 11:13 AM
umdpru's Avatar
Mine does that occassionally. It's a bulb problem as I had the ballasts replaced. It doesn't do it often enough for me to get the bulbs out and replace them even though I already have some on hand.
Old May 14, 2012 | 07:53 AM
cherylchristine33's Avatar
Please try with another HID Ballast or HID bulb. If you find a problem with either of this, buy a new one from a guaranteed dealer.
I am suggesting you to try with sparkhid. They have wide variety of guaranteed products with reasonably low price than local dealers.
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
jomax14
Aug 12, 2015 11:49 AM
kirkhilles
Aug 8, 2015 10:53 AM
