starting troubles again
Old Nov 7, 2011 | 09:19 PM
Perseus's Avatar
when i bought my max half a year ago it had starting issues. sometimes it started perfectly fine while other times i didn't get any reaction from turning the key until the 2nd or 3rd turn. i replaced the ignition switch and everything seemed fine after that, but recently the same problem has come back i remember reading about people facing the same scenario but i don't recall what they did or where i could read it again. does anyone know what i should do?
Old Nov 8, 2011 | 07:35 AM
bobflood's Avatar
If it's doing exactly the same thing as last time, and replacing the ignition switch fixed it before, I would look to make sure that the new ignition switch was not coming loose from the key cylinder, and that it was still plugged in well.
Old Nov 8, 2011 | 07:57 AM
DennisMik's Avatar
What people have done is to remove the ignition switch and insert a small piece of duct tape in the slot where the key goes into it. This causes the ignition switch to get turned a little bit more. It is not a guaranteed fix. It works for some but not for others. You may still need a new ignition switch as BobFlood suggested.
If you do this, don't use a giant piece of tape as it can jam.
Check out this link, specifically the photo in post # 36.
http://forums.maxima.org/4th-generat...start-car.html
Old Nov 18, 2011 | 03:52 PM
Perseus's Avatar
thanks guys. tested out the ignition switch and it worked so i put on 3 strips of duct tape. hopefully this fixes it, but i guess i won't know for sure for a while...but for now, onto the next job
Old Nov 23, 2011 | 01:53 AM
Zubriski's Avatar
mine turned out to be the starter, thought it was the ignition switch did the 'fix' but it would continue to have problems, more and more frequently. Finally changed out the starter and no problems since then.
Old Nov 23, 2011 | 05:06 AM
wirelessdude04's Avatar
So it doesnt even crank sometimes or when you turn the key you get nothing?
bryants95max
Oct 2, 2015 12:52 PM
QueensMAX
Sep 15, 2015 04:14 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
