Looking for a AMP for Pioneer Subs
Old Nov 17, 2011 | 07:00 AM
inixratedini's Avatar
i have 2 brand new Pioneer Premier TS-W2502D2 800 Rms - 3000 max. I'm looking for a recommend amp for this.
Here's a Link for some specs
http://www.sonicelectronix.com/item_...S-W2502D2.html
Also what type of box should i use?
Old Nov 17, 2011 | 05:45 PM
Car Addict's Avatar
build box to specs in the manual
budget?
Old Nov 18, 2011 | 04:51 AM
i'm not trying to spend anything over a grand so probably if i can like around 700 or so. I was looking at this hi fonics amp but i'm not sure if it's a good amp.
Old Nov 18, 2011 | 11:34 AM
Car Addict's Avatar
these if your gonna be running them at 1 ohm
http://www.audioque.com/AQ2200D-Amplifier_p_31.html
http://www.soundsolutionsaudio.com/s...1500D-v.2.html
Old Nov 18, 2011 | 08:59 PM
LudaTej's Avatar
Wow you're gonna be pushin' 2 of these?!? I would not be able to handle that much lol. But to each his own. Anyway, I would recommend getting a Class-D monoblock for the most efficiency. It will be difficult to find 1600W RMS in a monoblock though. The other route you can take is powering each sub with its own amp.
After looking up some amps I came across this Rockford Fosgate:
http://www.rockfordfosgate.com/produ...status=current
It's a 100W RMS short of your subs however. You can try looking up others yourself but this is what I found after a quick search.
Best price I found on it was here:http://www.onlinecarstereo.com/CarAu...ice_Comparison
Old Nov 19, 2011 | 10:24 AM
tseng1023's Avatar
IMO, using that beautiful Rockford amp to push these Pioneers is a HUGE waste. Out of the OP's budget range anyway.
I really don't have experience with Pioneer subs but remember, you get what you pay for.
@OP, seems like you just want something that SLAMS. I highly agree with you on the hifonics amp. The Brutus series amps would go perfectly with this setup IMO.
Good luck! keep us updated
Old Nov 21, 2011 | 06:44 AM
Thanks for all the info guys.
I'm not sure if it's safe to run these 2 subs now, this past weekend i hooked up a 300 watt amp w/ 2 sub about 300 watts each. Some stuff i had lying around, just to get a little more bump for now. Although it's not a powerful set up I'm getting a lot of rattle. I'm getting rattle from the wing, plates of course, one of my rear reflectors is apparently a bit loose and the weirdest rattle my back glass i couldn't believe that part.
I Have 5.5 Gen i had a clean carfax when i bought the car so i don't know why the glass is vibrating but anyways now i have to go research all the rattling issues because i hate rattling. So this setup might be on hold for a few.
Old Nov 21, 2011 | 09:21 AM
nismos14's Avatar
§è~® f®ÈÄk
I have an alpine PDX1.1000 that would work well, $325 shipped.
Old Nov 21, 2011 | 11:58 AM
Car Addict's Avatar
all you need is some fatmat
Old Nov 21, 2011 | 06:20 PM
tseng1023's Avatar
Stiffen up the metal, I suggest Second Skin sound damping.
worldwiderecognized
Sep 30, 2015 01:16 PM
sliptap
Sep 30, 2015 05:57 AM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
