Right turn signal gets no power?
Old Feb 11, 2012 | 08:30 AM
imaking133's Avatar
Has this happened to anyone before? I guess I have to trace the wire and see if I can find where it is broken.
I already did the obvious, changed bulbs, and i plugged the light in on the front left side instead of the right. It works fine.
Old Feb 11, 2012 | 10:32 AM
Amerikaner83's Avatar
is this the interior, with the gauge cluster? Or is this one of the actual blinker bulbs on the outside of the car?
Old Feb 11, 2012 | 12:31 PM
Jason1979a's Avatar
Not a 100% sure about this but make sure your hazard switch is plugged in good. Only saying this cuz on most cars the blinkers pass through the hazard switch. also you could just have a bad switch on the column. I hope it is something simple for you. Is it both of the right side lights or just the front or rear. If it is just a front or rear disregard anything I said, Probably just a dirty socket at the light.
Old Feb 11, 2012 | 02:11 PM
imaking133's Avatar
Its the front right.
Old Feb 11, 2012 | 03:33 PM
Ok so if its only one of the blinkers, take a close look at the socket for the bulb. Corrosion any where? How about a loose or frayed wire?
plug the bulb in and out several times from the bulb socket...sometimes the contacts need a bit of cleaning and that's one way to do it
Old Feb 12, 2012 | 06:57 AM
imaking133's Avatar
I already plugged the same bulb/socket in on the left side and it worked fine.
Old Feb 12, 2012 | 11:08 AM
Then you're going to have to trace wires. If the bulb socket is ok then what about the socket connector to the car?
Old Feb 12, 2012 | 11:43 PM
CMax03's Avatar
Did you check your fuse? If the fuse is good maybe the culprit is the stalk!
rnb754
Sep 14, 2015 11:39 PM
LtLeary
Sep 14, 2015 12:33 PM
minsbang
Sep 11, 2015 08:48 PM
trungg86
Sep 4, 2015 04:58 AM
