What could possibly run with no key and no engine?
Old Feb 28, 2012 | 07:10 PM
Justaguy's Avatar
Hi,
(I've searched and searched)
After the car sitting for about 5 hours, I went out to start the car to go somewhere. I started the car but I slipped when cracking (didn't hold it long enough), I was just about to do a redo and I noticed a very weird noise coming from somewhere near the iacv, sounded like a blower fan. It was loud...I removed the key opened the hood and the noise was very strong (the engine is off!) I thought something was going to explode, so I try to start the car with that weird noise and all I got was those start-up lights, no crank, no nothing...
I then ran to get a wrench to disconnect the battery because for sure I thought something was going to blow up. Like a fan operating on a cold day, but the fan wasn't turning. The noise was around the battery iacv area...by the time I got back to the car, the noise stopped (it was maybe 2-3 minutes) and I was able to start the car..I had to crank it a bit (more than usual) but it started...it may have backfired but I'm not too sure.
My starter was replaced about 2 months ago, the iacv and egr was cleaned out about 1 year ago...I have no codes and I was able to start the car a few more times tonight (on my trip home). I have a full tank of gas as well.
Anyone know what the heck was that? It wasn't a ping but a constant loud noise..what could possibly run with no key and no engine?????
Old Feb 28, 2012 | 07:26 PM
Justaguy's Avatar
On google I found this
This is the motor mounts gone bad they can be unpluged or replaced to fix them you will have to have it in the air on a lift, to repair the mounts, they will stay on with the key off when bad, Thank You, XXXXX XXXXX know if you have any more questions, ROY!
http://www.justanswer.com/nissan/29w...e-several.html
weird...
Old Feb 28, 2012 | 08:53 PM
styliztik's Avatar
motor mounts being unplugged... make sure to check that blinker fluid!
Old Feb 28, 2012 | 10:00 PM
DennisMik's Avatar
I don't think Nissan put the electric motor mounts on the 4th gen. That started with the 5th gen.
Old Feb 28, 2012 | 10:05 PM
Amerikaner83's Avatar
According to the FAQ, auto SE and all GLE were equipped with electronic front engine mounts
Old Feb 28, 2012 | 10:16 PM
maxed_out_99's Avatar
Wow really? I'm going to have to check that out
Old Feb 29, 2012 | 05:14 AM
Justaguy's Avatar
I also thought that motor mounts were found in 5th gen and up.
blinker fluid? New to me, I'll look it up..
Old Feb 29, 2012 | 06:05 AM
ampire's Avatar
Yep. Switch to the MT Polyurethane Energy Suspension Inserts for the win.
Old Feb 29, 2012 | 06:57 AM
That won't rattle my teeth out? I have an auto
Old Feb 29, 2012 | 10:34 AM
DennisMik's Avatar
Well, that sucks.
It all depends on how smooth your engine idles.
Old Feb 29, 2012 | 12:05 PM
MaximaSpd85's Avatar
Sounds like Starter to me...
Old Feb 29, 2012 | 02:00 PM
Justaguy's Avatar
It's not the starter...The starter is new, and I have been driving around all day today with no problems starting (about 8-10 times). I have an automatic.
Old Feb 29, 2012 | 02:10 PM
IslandMax's Avatar
My 98 has an electric motor mount, some 4th gens came with them (just the front torque mount).
You need narrow down where the sound is coming from. From the fans, tranny side, timing cover side, firewall.
Old Feb 29, 2012 | 08:23 PM
Everything you just said means absolutely nothing. You think if a starter starts to go bad the car will never start again?
The reason i said starter is because its happened to me before. I buy a brand new starter, take it out the box, bolt it in, hook up the battery cables and the bendix starts spinning right away.
Old Mar 1, 2012 | 03:11 PM
njmaxseltd's Avatar
This is most likely what happed to the op of this thread.
Not very uncommon.
Old Mar 1, 2012 | 06:03 PM
Fauken's Avatar
So where gxe with some options, mine is unplugged as well
Old Mar 1, 2012 | 06:06 PM
Kuhn_man's Avatar
just cause its new doesnt mean it works correctly, ive had the same problem the starter solenoid keeps the starter turning with out it being enguaged to the flywheel...honestly its probly the starter
Old Mar 3, 2012 | 04:37 PM
jholley's Avatar
After turning my MAX off in the parking lot today there was something still operating in the engine. I popped the hood and could hear the starter so I reached down under the air duct and disconnected the IGN wire from the solenoid switch. This is why having small hands has it's advantages.
It wouldn't start back up again so my wife came and picked me up then drove me back with the tools. I first measured the 24F battery and it still had 12.6V even though the starter just partially drained it for around a minute. I then measured the voltage on the disconnected solenoid switch IGN wire and it was reading a constant 9.8V. That confirmed this 8 month old refurbished starter had a shorted solenoid switch so I dismantled it and had my wife take me to Advance Auto. I traded it in for another refurbished starter and had them bench test it first. After easily installing the refurbished starter she started up within a second.
This is the third time within 16 months that I've burnt the elctromagnetic coils in the solenoid switch. I don't hold the key in start for more than 1 second. A 24F battery has more cranking amps than the 35N and I have a 2 AWG GND wire connecting the NEG terminal to the long starter mounting bolt.
Do you think I might be giving the solenoid switch too much current? I'm going to borrow a friend's carbon bile tester tomorrow to compare how much current is drawn during startup with/ without that starter GND wire connected.
alixc
Aug 11, 2020 01:48 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
