Clutch replaced ... pedal feels soft!
Like the title says ...
I had my clutch replaced today with an Exedy OEM clutch kit. Everything is working ok, but my pedal feels way too soft. I know people have mentioned this issue here, but I didn't think it was going to be that bad.
It feels like the time my slave cylinder/hose went out minus the pedal getting stuck/fluid lost.
I'm not having any issues changing gears or anything. I didn't get the Stage 1 because I don't have any mods and this is my commuter vehicle.
I replaced the flywheel with a new one and got an NTN TO bearing (instead of the chinese one included in the kit). All fluids were replaced during this replacement (Amsoil GL-4 and Amsoil brake fluid).
Should I try to bleed the system again?
TIA,
G
TIA,
G
try bleeding it again, sounds like theres still air in the system. if after bleeding it again you still get the problem i would be looking for clutch line leaks, if none i would look at the slave cylinder
TIA,
G
TIA,
G
If so, then absolutely yes, bleed it out, clutches can be tricky to get completely bled, just make darned sure that reservoir doesn't get low, it's a small one and it's simple to bleed it dry.
If you didn't remove any clutch lines, look for lines that could have been disturbed and might now be wet with fluid. This is most likely at one of the fittings for the slave cylinder.
Unless of course the old stuff had a higher clamping force than the replacement part.
Just talked to the shop that did the work. They bled the system and most likely didn't bleed it right. I'm taking it again today ... I mentioned the two bleeding screws and I'm pretty sure they only bled the upper screw.
Thanks for the advice!
I have a 5-speed which comes with a sprung clutch IIRC. Exedy OEM tend to be softer than the OEM units. I'm ok with that, but it seems that the hydraulic system needs to be bleed because there's absolutely no pressure when I press the clutch pedal. Fluid level is fine. Slave cylinder and hose were replaced last year and there are no leaks.
They bled the system again and the pedal feel has improved.
Now I have another issue. I guess my driver's side axle seal got messed up and I found gear oil on my driveway and at the store parking lot. I had no clue that these needed to be replaced and the mechanic didn't mention anything about it either. Dropped my car at my preferred mechanic because I don't trust the shop that did the clutch work anymore.
I hope this is just the axle seal and not a diff bearing issue. I didn't have any leaks prior to the clutch replacement.
1st, I bet they removed the Slave cylinder line or at least loosened it, not having a fkcuing clue what they were doing (because you don't need to touch it)
And 2nd, they obviously fkcuked up your seals or worse when they pulled/reinstalled the axels.
Go back to them. Tell them you want them to pay for it to be fixed by a reputable shop. or at least them re-do the work PROPERLY.
Threated ot call BBB if they get their backs up. If that doesn't work dunno guess sue the dumb fuaks.
WOW those guys messed up this job HARD.
Yep ... I'm dealing with this BS tomorrow.
I just want to confirm here that only the driver's cv shaft needs to be removed for a clutch replacement.
G
I had same issue when i replaced the clutch in my 01, then my 04. Its just that the new pressure plate has less give. If you have no problem shifting, plenty of clutch fluid and no leaks from the clutch system you should be fine.
Just cause it's been said twice for some reason I'll comment on this:
1. Pressure plates don't have give. They are a solid piece just like your flywheel's friction surface.
2. Even if somehow they DID have give (they don't), Something that has LESS 'give' would result in a FIRMER pedal, not a 'soft' feel which is what the OP is describing.
Just got the car back ... what a day. Labor was covered, but I had to buy the axle seal. Didn't think it was a big deal, but I was wrong. Had issues finding the seal (only one was leaking). I when I found them, I found to different styles. One was mostly plastic with hard plastic located where it sits in the cavity (CarQuest brand) and another one that was half plastic/half metal (NDK). I dropped the CarQuest one first, but told the guy not to install it until I confirmed that it was the right one. He freakin' installed it anyways after I got the NDK (which are the OEM ones). So far no leaks and I hope it doesn't leak in the near future. I personally checked the shaft play and it was solid ... so the bearings are good.
And by them, I mean them. As soon as you remove an axel the seal is *SUPPOSED* to be replaced.
When you are pulling hte tranny though, it's just something you do without thinking.
When you're replacing an axel, it's not uncommon to skip changing the seals. As long as you're careful it's not that bad to skip it.
In your case you should have done them both if they covered labour, good on them for doing that though!
Should have just got them right from Nissan.
Thanks for the advice guys!
G
vingodine
45
May 21, 2016 12:46 PM
Starrider
Sep 17, 2015 07:26 AM
