Shifter Knob Moving Around While Driving Normal??
Old May 7, 2012 | 11:29 AM
DjHackStyle's Avatar
Shifter **** Moving Around While Driving Normal??
car - 2003 Maxima 6 Speed Manual HLSD
when im driving and taking off i feel the shifter **** moving around, like when i engage the clutch the shift **** moves back in any gear it physically moves like half an inch front to back only movement only, no side to side. even when im slowing down if im in gear the shifter **** is rocking back and forth. it does not effect switching gears, it works perfect. it just rocks back and forth all day long.
in order to solve this problem i replaced front and rear mounts with ES torque mounts http://www.partsgeek.com/assets/perf/full/1235701.pdf
i replaced drivers side mount with a beck arnley mount and i replaced the transmission (driver side) mount with a OEM nissan mount straight from the dealer cause i couldn't find it anywhere else.
i also replaced the shifter cable and linkage bushings from Energy Suspension aswell, cause the forum recommended it http://www.partsgeek.com/assets/perf/full/1235703.pdf
i still have this problem, and after all these new parts, it is still EXACTLY the same as day one. please help, this is so weirddd.
VIDEO UPLOADED ! - http://www.youtube.com/watch?v=q2PJ9ctbjcI
Old May 8, 2012 | 11:46 AM
So nobody has a clue? Would a video of the movement help?
Old May 8, 2012 | 12:07 PM
MrEous's Avatar
^ Jeff™
Yes that would help
Old May 8, 2012 | 02:55 PM
knight_yyz's Avatar
Toolie
it moves around in a 6 speed, when you tap the gas, let off the gas
Old May 8, 2012 | 04:24 PM
thats exactly what im talking about, thats why im buying that prototype motor mount from you......cant wait for it.......and hopefully it will minimize this effect.........so just to get this straight this is actually NORMAL ?
p.s. video uploaded !
Old May 8, 2012 | 04:44 PM
whiteSE's Avatar
that is perfectly normal. all my cars did that. nothing to worry about
Old May 8, 2012 | 04:45 PM
EuroDriver's Avatar
It's been a few years since I have owned a manual, but every manual tranny vehicle I have ever owned or driven, the shifter moves when you accelerate/decelerate. I'd say it's normal.
Old May 9, 2012 | 11:18 AM
wow, ok guys i guess i was just bugging out, good to hear from the forum, ill leave it alone.
Old Jun 8, 2012 | 09:07 PM
VisciousMo's Avatar
I'm going to bump this thread because I'm having the same issue in my 5MT in 3rd, 4th, and 5th. But, my movement is a little more than his. Now, I could care less about the movement. the problem is, IF AND ONLY I go to redline in 2nd gear...and I shift to 3rd...it will grind.
Under normal driving conditions, 3rd will not grind. Even, at 4-5K RPM...smooth shift.
I have 3 poly mounts, and about to replace my tranny mount sunday. My shifter linkage is kind of wobbly but I believe there should be some play in it. Any help would be greatly appreciated. I've been plagued with this problem for months now. The tranny was rebuilt about a year ago with fresh synchros
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
Matt93SE
May 24, 2019 02:58 PM
Maxima30
Sep 7, 2015 06:13 PM
dcardello
Sep 3, 2015 11:44 PM
