2001
Old Jun 24, 2012 | 04:57 PM
suecer's Avatar
2001
hi folks its my first time posting some problems with my 01.
First of all the support where the radiator is sitting on is rusting very bad, secondly i have a code 403, i am in brampton Ontario area need a good body shop... and what part to clear that code 403.
hope someone have any suggestions on my problems
thanks
suecer
Old Jun 24, 2012 | 05:15 PM
ViRTualTeRRoRisT's Avatar
Had the same problem on my 01 SE. You have two options when it comes to the rad support. You can either disconnect all the wiring, hoses, cross member and whatever else to unbolt the old support and just throw on a new one, or have the current one chopped and have a non-rusted piece welded back on. I'd personally prefer to do the unbolting and go thru all that work cause then you wont be relying on the body shop's welding abilities.
Old Jun 24, 2012 | 05:20 PM
VQP0WER's Avatar
Please verify the trouble code. Is it a P0403? I don't see how that's possible since 2001+ Maxima's don't have EGR's. Do you know if the ECM was replaced on it?
Old Jun 24, 2012 | 05:28 PM
suecer's Avatar
yes its P0 403
Old Jun 24, 2012 | 05:31 PM
suecer's Avatar
thanks for your quick response is that cross member attach to the body of the vehicle left to right and the front engine mount is on that same support i think
Old Jun 24, 2012 | 05:39 PM
I'm not really understanding the question. The cross member has to be bolted to the vehicle otherwise it won't be doing what it's meant to do. And there is a motor mount on the front of the cross member facing the firewall. I can't remember if there are two mounts or just one on the cross member.
Here's a pic of how bad my situation was:
Old Jun 24, 2012 | 05:49 PM
cjandura's Avatar
2 mounts just pickup the lower support. And replace it try to go oe because its stronger it is going to take a few hours to get it off there and drilling out spot welds is required
Old Jun 24, 2012 | 06:38 PM
DennisMik's Avatar
As for the P0403 code, go get the codes checked. I don't think there is a P0403 code. I wonder if it is code P0430, which is "3 Way Catalyst system efficiency below threshold".
Old Jun 25, 2012 | 12:15 PM
suecer's Avatar
sorry guys it was code P0 430...
Old Jun 25, 2012 | 02:37 PM
VQP0WER's Avatar
No problem The P0430 code is pretty popular on these cars. Type in P0430 in the search box at the top of the page.
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
Tmax78
Sep 25, 2015 09:07 PM
QueensMAX
Sep 15, 2015 04:14 AM
