Changing ignition coils and spark plugs. Any good vendors?
Where would you guys recommend getting spark plugs and ignition coils from? I understand that OEM coils are pretty much manditory if I don't want the SES to remain on...
i bought some of my coils from Napa, Advance Auto, and Auto Zone and haven't had a problem yet ...
I would suggest getting coils ( all 6 ) from one place so IF they ever go bad you can get them warrantied ( IIRC Advance Auto has lifetime warranty on the coils )
I'm not sure about the specific part number, but the part number for all 6 should be the same as they can be swapped from cylinder to cylinder with no problem.
For spark plugs go with NGK Iridium's.
http://rockauto.com/catalog/x,carcod...,parttype,7212
get the spark plugs cheaper here, get the NGK Part # 6240 {#PLFR5A11} Laser Platinum
thats the original plug that comes on the car from factory, cant go wrong.
thats for a VQ35, u didnt mention which engine.
He lists his car in his sig as a 2000, so it's the De-k 3.0, which has different coil packs front and rear.
OEM for me...too many horror stories with AZ/Advance/O'Reilly coilpacks..... My "03" originals were removed from service @ 139K and were working fine...Hope you can get 9 yrs of service out of those aftermarket parts.....
Front: 22448-2Y005
Rear: 22448-2Y000
So, I guess the question now is: OEM spark plugs or aftermarket?
you should check the TSB, there was a recall on them and if you still have the original ones - you might be able to get them replaced to white dot ones at the dealer
RealityCheck
Aug 5, 2015 06:18 AM
hopefully this will be the end of the SES for a long while.
