96 Max with no spark On cyl1 only?
Just had a 96 Maxima SE roll into the shop today with code P0301 for cylinder 1 misfire car has 180k on the clock and had never been tuned-up so after installing 6 new plugs code reoccurred pulled #1 coil pack and found no spark, replaced coil with new Napa Echlin coil and still having the same problem except for the coil was hotter than a firecracker. Any Ideas Would Be greatly appreciated.
1) Replace all spark plugs.
2) Replace Ignition Coils with OEM ONLY!
3) Make sure you're replacing the right bank.
::Firewall::
1 3 5
2 4 6
::Radiator::
4) Check the Ignition Coil harness.
::Firewall::
1 3 5
2 4 6
::Radiator::
Somebody correct me if I'm wrong but I think our coils fire from a grounding signal from the ECU. Therefore, they have a constant voltage present. Now if by chance the signal wire gets shorted to ground, a continuous current will pass through the primary side of the coil which will definitely cause it to cook.
Just a thought...
Just a thought...
Just a thought...
Just a thought...
Need help
23
Oct 2, 2015 08:56 AM
