Car sluggish
Old Aug 17, 2012 | 04:30 PM
bennuss's Avatar
Car sluggish
My car started driving sluggishly after I did a drain and refill of the ATF. I used Supertech DexronIII/Mercon.
Do you think that is the problem and should I change it to a different ATF?
The manual does state that dexronIII is a valid replacement or maybe it is the brand?
From what I understand Supertech ATF is manufactured by TEXACO or valvoline depending on which one.
I read all the threads and did not find a conclusive answer but many people said Mobil 1 Synthetic which states certified for matic d is better.
Old Aug 17, 2012 | 04:46 PM
foodmanry's Avatar
Da Roller Coaster!
Any dex III will be fine. Check your fluid level as over or under filling can cause your symptoms.
To check:
-car and transmission must be at operating temperature
-cycle through all gears including 1, 2, 3
-find level surface
-put in park with engine running
Old Aug 19, 2012 | 05:46 AM
bennuss's Avatar
I usually check it with the cold marks. I turn on the engine cycle through and check with engine running. It is at the top of the cold mark but not above. Should I remove some fluid?
Old Aug 19, 2012 | 08:09 AM
foodmanry's Avatar
Da Roller Coaster!
No, there are "HOT" marks on the dipstick. You need to make sure both the engine and transmission are warmed up sufficiently. This means going for a drive, 5 to 10 minutes should be sufficient in the heat.
If it is above the "HOT" mark you should definitely remove fluid.
Old Aug 19, 2012 | 09:12 AM
luvlexus101's Avatar
I believe another factor I found is whether you're checking the fluid with the car on or off.
Old Aug 19, 2012 | 01:28 PM
foodmanry's Avatar
Da Roller Coaster!
Uhhhh...yeah, see my first post "engine running".
Old Aug 19, 2012 | 05:01 PM
bennuss's Avatar
Thanks so I checked it and it is at the top hot line maybe very slightly above. Should I take out so that it is in middle of the lines? How much do you think that is? A pint ?
Old Aug 19, 2012 | 05:11 PM
foodmanry's Avatar
Da Roller Coaster!
Yes. Use a clean bottle if you can. This way you can pour back in if you take out too much.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
