Unorthodox UDP help
Unorthodox UDP help
So, I bought a used Unorthodox Racing underdrive pulley. Looks like they used a pry bar to pull it off the crank instead of using a proper puller. As a result, the timing ring is slightly bent in some places. I removed it and tried straightening out as best I could.
Does anyone know where I can purchase a replacement ring? Or has anyone ran a udp with a slightly bent timing ring with no issues?
I think it time to go to ASP racing and have them make 2 4th gen crank pulleys....a OEM size billet aluminum pulley and an underdriven pulley.....I was busy in the several projects I have/had on my plate....The 4th gen MES catback, The Cattman 3" Hybrid Resonator section for the 5th Gens, and several cars I've been working on locally...I'll start by mailing the one I have to ASP and we'll be rocking real soon!
I was just a bit paranoid, cause I remember reading a post on someone using an OBX pulley with a slightly bent ring and the car ran like ****...
vtec killer
Nov 18, 2000 05:53 PM
