Sponsored by:
Sponsored by: CARiD
VQ35HR, running with a VQ30 ECU (swap)
Old Oct 25, 2012 | 12:25 PM
MarcL's Avatar
I asked this about 2 yrs ago.. Back then, no one had tried it.. Wondering if anything has changed....
Can I swap a VQ30 timing set, and oil pan on the VQ35HR motor? Run it with the VQ30 ECU?
Did any of the accessory mounts on the HR block change? Like, for the AC compressor?
My setup right now is running 2002-2008 style Maxima engine with the VQ30 timing, and want to know how practical it is to go with a VQ35HR instead.
Old Oct 25, 2012 | 01:49 PM
t6378tp's Avatar
Turbo 3.5
Someone has to be the 1st and I vote for you to be that person
Old Oct 26, 2012 | 08:14 PM
L36's Avatar
L36
There is no FWD variant of the HR. Since the mounting locations are different when comparing the FWD and RWD VQ, you not only have to worry about your current issue, but the mounting as well. If you have the time and disposable income to do it, be the first.
Old Oct 27, 2012 | 06:33 AM
MarcL's Avatar
Sorry, I was referring to the 2009+ Maxima VQ engine, with the HR heads.. Not the RWD block.
Old Oct 28, 2012 | 12:02 PM
SurraTT's Avatar
HR Swap Pioneer
The 09 Maxima motor will work the same with 3.0 timing.
Its a lot of $ to spend on a motor just to dumb it down with 3.0 timing.
Old Dec 27, 2012 | 10:08 AM
aackshun's Avatar
Just get some big boy cams in there and a real tuning solution. Go do it.
Old Dec 27, 2012 | 03:05 PM
Crusher103's Avatar
This is what i was thinking, its not really worth it, just get a normal 3.5.
Old Dec 27, 2012 | 04:08 PM
mrbat's Avatar
I would say the same but then again if you think about it in the long run if he keeping the max and only doin bolt-ons then i can see the hassle of goin that route.
OSent from the batcave
Old Dec 27, 2012 | 08:55 PM
asand1's Avatar
I think its for his Delorean, not a Max.
Old Dec 29, 2012 | 12:22 PM
asand1's Avatar
Originally Posted by 5er
Ummm, well I just bought an 11 altima 3.5 for $550 shipped so price wise, there's no issue imo, assuming the seller ships lol. http://www.ebay.com/itm/ENGINE-2011-...e06163&vxp=mtr
And you jacked this thread because??
Old Dec 30, 2012 | 10:17 AM
aackshun's Avatar
The motor you purchased and the motor the OP is talking about are not the same one...
You're at least 20hp, quite a few CC's in the intake manifold department and one pair of variable cams short of the motor in the original post....
One would just simply say you're just poasting away like a jack@$$.....
Old Dec 30, 2012 | 12:46 PM
5er's Avatar
5er
It's practically the same. http://forums.maxima.org/all-motor/6...08-altima.html
Old Dec 30, 2012 | 06:59 PM
95naSTA's Avatar
Can 1st gen vq35 cams be used in the 07/09 style heads?
Old Dec 30, 2012 | 07:41 PM
aackshun's Avatar
Yes/No.
If we pretend the 09 is the HR motor then you would need timing adapters for the cams.
The 07 Maxima is the same as the 02 maxima.
The 07 Altima v6 is different slightly, but I would venture out and say it's different just because of the position of the VCT actuators.... This is nothing a FSM can't answer for you though....
Old Jan 1, 2013 | 03:10 PM
95naSTA's Avatar
I should have been more specific.
If you were going to use 3.0 timing equipment on a 07+ Altima or an 09+ Maxima engine, could you use older 3.5 DE cams?
Edit-
Found my answer: http://forums.maxima.org/8312753-post16.html
cruce91
Sep 20, 2015 10:23 AM
Slamrod
Sep 3, 2015 07:38 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
A32goldylocks
Sep 2, 2015 06:39 AM
