Clutch Repair Advice?
Old Nov 13, 2012 | 04:31 PM
Etheostoma's Avatar
My 5th gen 6-spd has 138k on the original clutch and I recently starting hearing the throwout bearing whining. I figured it would be a good time to replace the entire clutch assembly knowing the labor wouldn't cost much more. What I didn't know is that the flywheel is dual mass and cannot be resurfaced. New flywheels appear to cost $400-$600 depending on source and the overall cost of replacing the entire clutch was quoted at $1,900 by my mechanic...
What would you guys do? Drive it for a while until it totally craps out? Replace the clutch kit, but not the freewheel? Replace it all? Thanks in advance for constructive input.
Old Nov 13, 2012 | 04:42 PM
nsnrider's Avatar
i've replaced the clutch set without having to resurface/replace the flywheel. if your flywheel is in good condition then you might get away without having to do anything to it. JMO.
Old Nov 14, 2012 | 08:43 AM
Etheostoma's Avatar
Right on. Thanks for the reply. I'm getting conflicting opinions from shops/friends. Some say that the flywheel cannot be resurfaced since it's dual mass...some say it can be. No matter, I know a guy that will do the work for $1,100 without resurfacing/replacing the flywheel (unless needed), which I figure is fair.
I guess my main dilemma is whether or not I continue putting money into the car. It's been taken well care of, and I love the thing, but repairs seem pretty expensive. I'd be stoked to get another 60k miles out of it, but dunno how long she'll last. As with most '02-03 VQ35DE engines, mine burns oil at a pretty fast rate. There's also a mystery rattle at approx. 2k rpm, especially under load. Sounds like nuts and bolts rolling around in a coffee can
Old Nov 14, 2012 | 09:06 AM
benjie's Avatar
Is that 1100 dealer parts plus labor or just labor. It seems a little high especially if it's just labor. I thought average clutch job on the high end would be about six bills.
Old Nov 14, 2012 | 09:14 AM
Etheostoma's Avatar
That's the quote for parts and labor (replacement of entire clutch assembly; clutch disc, pressure plate, throwout bearing, pilot bushing).
Mahmuth
Aug 16, 2024 08:23 PM
mkaresh
Mar 12, 2018 06:48 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
