I need a list of the things I need for TC job
ive done my research but cant find too much specific info I need for a tedious job involving the Timing Case..
I am getting an oil leak from the TC so I know I need those 2 o rings but I need part numbers so I can purchase them on courtesy. I will be very thankful for whoever can give me the list of things I need while doing this job so I never have to go back in there, thank you.
Posted from Maxima.org App for Android
Although its not mandatory, It would be a good idea to get a new tensioner and water pump and replace them while your in there. IIRC they have a TC gasket kit to replace all the gaskets and what not for the job. Im not to sure if courtesy carries a kit or not. You will need some rtv as well. Preferably a tube that can go into a caulking gun. Im sure there is more to the job but those are some things i can think of off the top of my head. GL
Does anyone know the part numbers for the tensioner, guide, and o-rings and oil pump seal ? I cant seem to find them and should I just replace the one tensioner with the spring/piston in it or do I need all tensioners ?
The napa part # is 9-4207sx for the chain kit it includes all 3 tensioners, all the guides, and cam sprockets. However, do yourself a favor because Napa is going through a vendor change do not let them give you the Taiwanese garbage "Lesson learned" the timing case job is not one you want to do twice. I was able to get a replacement kit made in Japan that is absolutely silent. the taiwan parts Clattered like no tomorrow.
