My K&N sucks....
My K&N sucks....
A few weeks back I pulled my air filter out to take a gander, and I held it up to the sun and saw several small holes in the filter, as if someone had taken a pin needle to it?
When I cleaned the filter about year and half ago it didn't have the these holes before or after the cleaning... And now there is a small amount of dirt through out the intake pipe and i'm sure on MAF as well.. Anyways...I was just going to replace it with a Nissan filter and be done with it, but I thought that I would give another aftermarket filter a shot. So far these are ones I have found that I might consider using.
http://americas.cosworth.com/product...r-air-filters/
http://www.hks-power.co.jp/en/product_db/intake/db/4403
http://apexi-usa.com/shop/index.php/...ake-panel.html
http://www.aemintakes.com/search/pro...?Prod=28-20031
Has anyone used any of the above filters and liked them? And might there be other filters out there that you guys are using??
When I cleaned the filter about year and half ago it didn't have the these holes before or after the cleaning... And now there is a small amount of dirt through out the intake pipe and i'm sure on MAF as well.. Anyways...I was just going to replace it with a Nissan filter and be done with it, but I thought that I would give another aftermarket filter a shot. So far these are ones I have found that I might consider using.http://americas.cosworth.com/product...r-air-filters/
Here's more info on the HKS.
http://www.hks-power.co.jp/en/produc...ter/index.html
Originally Posted by KenBob
Never heard of R2C!! Looks like a decent system!!
Originally Posted by chrome91
arent K&N lifetime warranty? i would see if they'll give you a replacement
i got a K&N out of a junkyard 3rd gen and ran it for a while and had no problems
Originally Posted by shiloh51933
I've had my K&N drop for a while in my Max and 5thgen Lude with satisfaction. Some people expect too much from an air filter...
call up K&N and see if they will give you another one. for some reason the stillen one rubbed on something and it wore a slight hole in the filter. called up K&N and they shipped out a new one ASAP.
otherwise stay with the OEM filter.
I will not be contacting K&N for a possible replacement filter as I have always had the idea of a "serviceable" filter being sketchy. Now that I found this I will be using a one time use filter as they seem to do their job more effectively.
http://www.bobistheoilguy.com/air-fi...ltration-test/
Definitely leaning towards the Cosworth or the Nissan filter.
S1cTech
Aug 24, 2008 03:32 PM
f550maranello2
37
Nov 7, 2006 12:10 PM
i30dvr
Jul 12, 2006 12:53 PM
