Slow cranking, but battery is fine
Old Nov 27, 2012 | 06:21 AM
stockmax's Avatar
The car cranks very slow, almost like the battery is dead. But, the battery is fine, battery connections are fine (had both checked, including replacing battery, problem remains). Once the car is running, everything works fine, no dash lights or other electrical problems. Any clues as to what else could be causing this? Bad starter?
TIA!
Keith
Old Nov 27, 2012 | 06:27 AM
rebelhell's Avatar
Possibly bad starter. I'd start by checking the connections on your starter though. Also check your engine ground and make sure it's good.
Old Nov 27, 2012 | 07:29 AM
[s3]'s Avatar
Congrats, you have a dead/dying starter. It's on the verge of seizing, swap it out when you get a chance.
Old Nov 27, 2012 | 08:43 AM
DennisMik's Avatar
^^^ this.
The lubrication in the gear reduction section of the starter is drying up and the gears are binding. Sometimes you can re-lube them and the starter will work OK, but I think your starter is too far gone for this to help.
Old Nov 27, 2012 | 10:54 AM
stockmax's Avatar
Thanks, guys, for the quick responses. Mechanic confirmed it is the starter, he checked the rest of the electrical circuit for proper grounding, and the state of the positive battery connection, and all looked good. Oh well, figure after 153,000 miles, shouldn't be complaining too much!!
Keith
Old Nov 27, 2012 | 08:46 PM
stockmax's Avatar
So, got the car back, starts up great now! While it was there, also had him change the drive belts.
One thing we noticed when we got the car back is that the clock isn't lit up, and the trip odometer resets to zero every time you start the car. Bad fuse? If so, any idea which one? I pulled the fuse cover, and nothing said clock. It's night time now, so not feeling like investigating further, probably won't have a chance until the weekend, but if anybody has any ideas, would certainly appreciate it!
Keith
Old Nov 27, 2012 | 09:34 PM
stockmax's Avatar
Keith
Never mind, used Search, sounds like it's Fuse 12. Will change in the morning.
Man, this forum is helpful.....
Keith
Old Nov 28, 2012 | 08:04 AM
Finchum's Avatar
^thats why I join the forum of the car I drive on the day I buy it ;-)
Old Nov 28, 2012 | 08:08 AM
rebelhell's Avatar
Even so, I've never been a member of a more devoted group of car guys until I bought my Max. I love this car and I am glad you all do to. I just wish i had more $$$.
DJLAX152
May 4, 2021 11:46 AM
mvm062
Nov 30, 2020 09:00 AM
gustavison
Oct 4, 2015 06:50 PM
conansriver
Sep 11, 2015 10:26 AM
markevans999
Sep 10, 2015 04:29 PM
