fixing my flooded 98
well im having a fuel problem im not getting power to my fuel pump theres 2 plugs one has two wires no power the other has four wires only one wire is getting power i changed the three computers under the radio alt and starter the car started once then i put new oil new gas now wont start i tested the fuel pump works fine just not getting eough power maybe theres more relays and computer i dont know about any help will be
There is a fuel pump relay. It is located behind the kick panel on the driver's side. If the car has a sun roof, that relay sits next to the fuel pump relay.
Pin 11 of the ECU grounds out the energizing coil of the fuel pimp relay. The relay contacts close and power from fuse # 32 (15 amp) goes to the fuel pump.
