Port and polish lower manifold
Jus cause I have the top kinetix and I ordered nwp spacers, rear 04 maxima valve cover to fix the 5.5 faulty one, spark plugs and 350z injectors with fuel rails. So since I'm there I kinda wanna do the lower manifold but jus curious if there's gains or if it's worth it haha
Kinetix manifold is pretty well known to be a waste of money.
Truth is the stock IM on this car is fairly well done. I'm sure a nice port/polish will help though, as long as it's done well it shouldn't hurt, just stay away from the injection area, you can screw up fuelling if you smooth it out too much, or rather, rough it up too much.
Are you thinking of just die-grinding the rough edges and using an emery wheel to smooth things out? I think it's a decent enough idea, post pics/walkthrough if you go ahead with it!!
I dunno, dyno's don't lie, but then again I haven't had first hand experience, and I don't even remember where to find the threads that went over it all on the Maxima's.
I know the ones for the G35/350Z were a great big flop
Sounds good I'm jus thinking about smoothing everything on it and about the kinetix I'm not sure if its jus me or idk but I really did notice a diffrence. It's lighter the car respondes a lot better and know that I have my Megan exhaust, STILLEN pulley, big MAF, with STILLEN intake, and Cattman headers I think it really helps.
Unfortunately not tuned I have my vafc and aem wideband jus saving up to take it to the shop.
Do nwp spacers show gains?
My car smells a lot like gas all the time when I turn it on, will it affect it in any way if I don't tune ASAP?
Well considering these cars burn oil as it is, I'd get it tuned ASAP.
Running it like that will equal a surplus of fuel most likely, which can wash the cylinder walls and accelerate piston ring wear.
Mainly this happens at idle/low speeds, so try not to idle it much, warm the car up by driving it under 2000 RPM, NOT by letting it idle.
Bigger maf housing will read less air than what is actually there, causing a lean condition. Tune to add fuel.
"Scaling" the maf, I think its called.
And dude no one can tell you if it will make more power. I did mine because it was off anyways for other work. Id like to think it will, but its tough to say.
Above post is because I missed the 3"maf when you said your mods.
You will not be running rich, you will be lean. You need to address that now you can hurt the engine.
Id like to see your fuel trims lmfao.
I hope you're planning on a tune right after this, you're really pushing things without a tune this is all pointless and only going to hurt things. Sounds like a tune is on your 'hit list', you just might want to move it up the list a bit more
Anyways, here's mines that I did last night (RWD VQ35)
Before Polish/buffing, note how nasty and rough the casting left some of the surfaces
And after:
And after:
Is that good or bad??
Those afrs are fine at idle, if you have a wideband running just make sure it stays under 15.3 roughly under load or at higher rpm and you should be ok.
Putting the stock intake on for thedrive is a good idea either way
So it's fine and when I'm driving it goes crazy and when I let go of the throttle it goes like past 17.9 and it jus like ••••
If in gear, and you are moving, and you let off the gas, it should go offscale, lean. During a WOT run, what are the readings? Any logging capability?
Also, re: the porting the LIM, if that's done, my opinion would be to port match the heads.
It's never a stable solid number in real world driving the numbers change with the movement of the throttle and load....but on most part when doing a WOT power pull on a level long straight away the AFR readings should be pretty stable....and yes decel and throttle lift will result in a rise in the AFR lean condition reading as stated by NMEX....relax....!
What do you mean when you're driving it 'goes crazy'?
A nice polish to get rid of the casting marks is fine, I would NOT port anything, just my personal opinion. I think you're more likely to make things worse trying to port stuff.
Sounds good I was all freaking out thinking I had a bad o2 sensor. Well at full wot it goes to 12.8 or 13.0 it varies.
No, I don't have any logging capabilities. I haven't even installed my vafc yet but will do it before I head to the tune shop.
It's just mounted haha
Another question guys will I have to tune my car again if I add my fidanza flywheel I jus have it there but my mechanic told me to wait till my clutch starts going out its still the oem one.
Agree. I don't think port matching the heads, LIM, etc is worth the risk on this car, IMO, unless you're going ***** out racing.
Just with an emery wheel, taking casting marks out mainly
