Just replaced the starter... Symptoms&Thoughts...
Old Jan 11, 2002 | 02:46 PM
petemo95se's Avatar
Well, I was tired of getting the screaching noise at startup when it's cold and I didn't want to get stranded anywhere, so I replaced the starter.
First off, the starter noise happens only in the AM when it's cold and during the "start phase and immediately after".
If the car is warmed and I start it again, no noise.
Getting the starter off with a CAI is relatively, but it requires a LOT of strength to get that 17mm bolt off. You'll know which one it is if you do it. It is the one in the back where you have little leverage. Once it is off, you're home free.
The old starter (95SE) looked like it had 10 (maybe 8) teeths. The new starter has at least 12 teeth. I thought that it may not be compatible, but it is.
With the new starter in place, it starts up incredibly quick and it SOUNDS like a new-car starter. Almost has a "turbo" sound to it. Where before it would take 1-2 seconds to start, now it takes half the time.
So if you are thinking of changing the starter, be forewarned about that 17mm bolt. Get the biggest wrench you can get your hands on and
prepare to sweat. WD-40 didn't help much.
FYI.
Old Jan 11, 2002 | 02:50 PM
Jeff92se's Avatar
I'm needing a caw
Hehe! You said "teeths".
Good job on the starter.
Old Jan 11, 2002 | 04:18 PM
Mishmosh's Avatar
Re: Just replaced the starter... Symptoms&Thoughts...
I believe the old version is 8 toothed and the mid-1996+ newer version is 10 toothed. (Trust me... I counted)
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
cruce91
Sep 20, 2015 10:23 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
