Vibration at 65 to 75 MPH
Old Apr 29, 2013 | 12:45 AM
beach50's Avatar
I've noticed a bad vibration in my steering wheel when going 65 to 75 MPH. It's most noticable when my foot is on the gas pedal. The tires are new and I've had them balanced twice thinking that would solve the problem. The engine seems fine (205K+). Since I notice it more when my foot is on the gas pedal, could it be that the engine is sputtering at a certain RPM that's not noticable when driving under 65 MPH? Any thoughts or suggestions are appreciated. Thanks in advance.
Old Apr 29, 2013 | 01:33 AM
Aflion's Avatar
Sounds like a wheel bearing or ball joint.
Posted from Maxima.org App for Android
Old Apr 29, 2013 | 01:59 AM
Climaxx's Avatar
If its not what was mentioned above, try getting them rebalanced. I had to get my wheels rebalanced literally like 7 times before they got it right...
Fwiw, my vibration got really noticeable above 70.
Old Apr 29, 2013 | 03:39 AM
c_elliott's Avatar
Had the same problem on a jetta i got rid of a few weeks ago. Check all 3 above. Mine was balancing
Old Apr 29, 2013 | 10:09 AM
BlackThornDemon's Avatar
I had the same problem @ 75. If it clunks while you turn its your cv joints.
Old Apr 29, 2013 | 12:46 PM
bullet187's Avatar
Did you notice the vibration before you got the new tires?
Old Apr 29, 2013 | 04:09 PM
maxinout93's Avatar
check the above items, but if you are a little mech inclined check to see if you have loose suspension componets under the car, ball joint nut, axle nut, strut nuts ect. My wheel was shaking once and I had 2 loose strut bolts, problem solved.
Old Apr 29, 2013 | 05:35 PM
deezo's Avatar
Also, make sure the lugs are torqued to spec. I had that problem for years and one day I decided to use my torque wrench to lock them down and most of my vibration problems went away.
Old Apr 29, 2013 | 05:41 PM
c_elliott's Avatar
This aswell happened on a car i had a few yrs ago. Some tard where lived got caught taking lugnuts off cars in the complex.
Old Apr 30, 2013 | 10:38 AM
dagobx's Avatar
How are your struts? My indie solved the same sort of problem by replacing my struts afer checking balance, bearings, brakes, etc.
Old Apr 30, 2013 | 09:16 PM
ivorton23's Avatar
I had the same problem a while back...was a loose balljoint...also had a bent rim
user 11122324
42
Jul 18, 2022 03:35 PM
Apr 16, 2020 05:15 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
salty318
Sep 29, 2015 01:21 PM
