99 maxima - Key with chip - illustrated
Old May 22, 2010 | 08:46 AM
mbhang's Avatar
Hello all,
I faced a situation a lot of you must have faced - the slot for my keychain broke on my key. I tried epoxy and various other methods, typically, these would last anywhere from a few hours to a few months.
Needed a more permanent solution (thanks to airport scanner). I was travelling, and had to put my key chain and wallet through scanner - and I was watching the scanner, and clearly saw the chip inside.
Since it is a 99, with a chip and immobilizer, dealers charge an arm and a leg for a replacement key (wish replacement was as simple as going to a walmart).
I closely examined my key, and saw that there was a visible rectangular shape beside the part where the key meets the head.
I was able to nudge the chip holder out - and was able to determine a safe place to drill. This will also be useful, if you can replacement key from ebay, and then re-use the old chip.
Posting pictures to help others who might facing a similar situation.
Hope some of you find this useful.
Have fun.
Manish
Old May 22, 2010 | 08:55 AM
Spyguy's Avatar
I nominate this for the FAQ's section. Does anyone else agree?
Old May 23, 2010 | 10:45 AM
mbhang's Avatar
99 Maxima key chip with transponder and immobilizer
Adding "transponder and immobilizer" to the message - so that it shows up when somebody uses Search function.
I am doing so as I have been looking at the messages (used search for "Key transponder") - looks like broken keys is a fairly common issue - and I think a picture is worth a thousand words. The pictures do make it very easy to figure out where one could drill a hole in the key.
I guess, one could also buy a new blank off ebay, get it cut at a hardware store, and then insert the existing chip into the new key (obviously, this does not help if you lose your keys, helps only in a situation where your key is 'broken').
Old May 23, 2010 | 11:08 AM
aackshun's Avatar
+ 1 for FAQ/Sticky.
Old May 23, 2010 | 08:56 PM
PLUMMAXSE's Avatar
Thanks for the pics! +1 on the sticky, this needs to be posted! Just drilled my key. It was nice not having the chip in there while I was drilling!! Love this forum!!
Old May 27, 2010 | 11:11 AM
mbhang's Avatar
It kind of sucks that our keys as well as remote tend to be structurally weak - I have owned a few cars now, and I have had this issue only with the maxima key and remote.
The vehicle immobilizer (though helpful, especially if somebody is trying to steal your car - not much of an issue as car is pretty old now) adds insult to injury, by limiting where you can get a replacement key.
Old May 27, 2010 | 11:31 AM
EsQueue's Avatar
I had a situation where dropped my keys in a parking lot. I realized this when I was walking back to my car and saw it on the ground. My key was smashed and broken.
the chip managed to survive so I took it and the little metal to ace. They used the key part to make a copy and I used electrical tape to hold the chip in place. This worked well. I finally got an ebay blank and put my existing chip in.
Old May 27, 2010 | 02:23 PM
Daniel1120's Avatar
Just as an FYI to everyone regarding immobilizer keys. Locksmiths will make a duplicate for ~$60. If you lost your old key all together it goes up to $250. That involves removing the door panel, removing the door lock, dissambeling and decoding the lock, cut the key, program the key, then put it all back together. I know this because I used to work as a licensed locksmith in texas for 2 years.
I used to get people asking me if there was anyway to bypass their immobilzer system. I always advised against it. But, I did do it once for somebody.
Old May 28, 2010 | 01:05 AM
whiteSE's Avatar
why sticky? its not like its really important. and we just had out "stickies" cleaned. so idk, let the admin figure it out
Old May 28, 2010 | 07:43 AM
ThreePointO's Avatar
Originally Posted by Daniel1120
Just as an FYI to everyone regarding immobilizer keys. Locksmiths will make a duplicate for ~$60....
i went to home depot a few months back and they charged me $70. if you need a key thats prob the best place to do it, just call around to find one that will do it.
Old May 28, 2010 | 02:23 PM
dual's Avatar
My keys were destroyed due to dropping them and then dropping them after I had the hole drilled in it.
I just bought the blanks of ebay for $15 each. The local Nissan dealer programmed them and away I went.
Old May 28, 2010 | 06:11 PM
SImAxImA88's Avatar
i lost my keys altogether but lucky enough i have a 96 so my keys dont require a chip, but how ever i tryed to get a key made from the dealer and they said that they cant get the key code because the car was sold from a canadian dealership. so i have to find a locksmith that can produce a key from the lock. so this is just a giant headache. THANK GOD MY KEYS DONT HAVE A CHIP, I DONT KNOW WHAT I WOULD DO.
Old May 28, 2010 | 06:35 PM
EsQueue's Avatar
That shouldn't be so hard. I had a locksmith come and remade keys to my door and rekey the ignition of my 90 buick regal for $90 with spares. The buick uses 2 keys so I didn't mind him putting in a new barrel for the ignition.
Old May 31, 2010 | 09:18 AM
hobokenkid's Avatar
yes look around the key is prob no good at all. i do not have any original keys do a google search I got one key off ebay a few years back and it work awesome. just have to reprogram at dealer is eziest
Old May 31, 2010 | 11:38 AM
VQ30MPG's Avatar
If they did, you would have to buy a blank key with chip, get a locksmith to cut it, then get the dealer to program your car to accept it. You're lucky to be without the chip as most dealers charge around $100 for the service.
Old Jun 2, 2010 | 07:12 AM
plugeye's Avatar
please explain. i have no use for any alarm system on this car. i'm sure there are many others who share this thought. i have one busted key i had to repair with a strap of leather & put the good clicker board in the unbusted but non-operational case.
Old Jun 10, 2010 | 02:17 PM
SiathLinux's Avatar
I'll add photos of my after market replacement key - with transponder chip - as these keys are MUCH cheaper than the OE - but I understand that you have to go to a dealer to 'set the chip' in them, but if you have your OE 'broken' key with it's chip - do a nice swap into one of the aftermarket keys and viola -0- save a ton of money...
Old Jun 10, 2010 | 07:51 PM
DennisMik's Avatar
A way to cheat is to take a chip key and tape it inside the plastic cover around the ignition switch. Then you can use a hardware store un-chipped key on your key ring.
You can't always swap the chip between keys because different key manufacturers use differend shaped/sized chips.
Old Jun 11, 2010 | 04:42 AM
plugeye's Avatar
thanks to yall that suggested taping the key inside the column, worked for me. slowly things are getting fixed on this old car & i actually look forward to driving it on the rare occasion that i dont ride a bike that day. now if i can get the air working we're in business.
Old Jun 11, 2010 | 12:35 PM
SiathLinux's Avatar
not sure why my picture isn't showing ... however the chip in my key is 'similar' in shape and size and 'bracket' looks nearly the same too.
2nd try for the image: (link and image)
http://farm5.static.flickr.com/4030/...96ee1612_b.jpg
Old Jun 11, 2010 | 04:16 PM
Daniel1120's Avatar
Sorry I never reposted back. DennisMlk hit the nail in the head. The key you use to tape up their will fit better if you cut off the actual key part. Make sure to use strong tape and don't put it to far away.
Old Jun 11, 2010 | 05:19 PM
LeFrank99's Avatar
maybe not a sticky but still, I have 2 keys with chip and both are broken, did exactly the same thing
Old Jun 12, 2010 | 06:50 AM
SiathLinux's Avatar
It's all good - I think that the 'other' aftermarket key, the holder part is more of a 'plunger cover' than a real holder and the chip is larger than the OE one...
Guess the most important thing here is to save money on having to get a set of keys registered to the ECU... no matter which method you use (attaching chip to car/putting old chip in newer key/whatevermethodyoucansavemoney), I know that eventually I will get an OE key for the car, just due to the fact that I want it to have the Nissan Logo on it.
Old Oct 25, 2010 | 04:41 PM
gulleyman's Avatar
I saw a rubber sleeve for these keys in the "help" section at a local auto parts store for just a few bucks. Just slips over the key like those colored identifier sleeves.
Old Oct 25, 2010 | 04:46 PM
99greddymax's Avatar
i used an 1999 i30 key... metal key ftw! got two keys for like 40 something and just swapped out the lil chips inside for my stock ones.
Old May 1, 2013 | 06:18 AM
Notary Sojac's Avatar
Thanks to the posters here
I was getting pretty tired of having to carry my ignition key in the zipper compartment of my wallet. Both my keys had suffered from "incurable Maxima key loop rot".
Bought two key blanks on ebay, had them cut at a hardware store, swapped the chips from my old keys with the help of my trusty SAK, now I'm good to go.
Thanks to all you fellow max drivers!!
scutmud
Aug 16, 2018 10:56 AM
ah2002
Mar 9, 2016 01:42 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
doobadoo
Aug 15, 2015 06:43 PM
