Looking to replace just the mufflers
Old May 15, 2013 | 07:57 AM
Fundem's Avatar
I'm pretty happy with the performance of my maxima (R2C, Y-pipe), but i want a little sound. I was thinking of replacing just the mufflers w/ universal Magnaflows. Does anyone the size that would replace the factory ones? Has anyone done this before?
I'm thinking center/offset?
Old May 15, 2013 | 09:11 AM
dr_2010SV's Avatar
Old May 15, 2013 | 09:14 AM
PSU09MAXIMA's Avatar
I like the Flowmaster 40 series mufflers there are clips of it on 7th gens on youtube
Old May 15, 2013 | 09:17 AM
Fundem's Avatar
Originally Posted by dr_2010SV
Lol, those are the exact ones I was looking at, they make the exact sound I'm looking for... what worries me is that he doesn't have a y-pipe in the clip and I do.. So I assume they'd be much louder with one?
I was looking for the size of the in/out and to see if it center/offset etc. Whats the largest muffler we can fit under there if I go universal 14", 18"? I'd just stick on the stock tips.
Old May 15, 2013 | 09:30 AM
J.lee's Avatar
Was there any major sound/performance change with just the y pipe install? I'm assuming there would be a sound difference, or is it not very audible?
Old May 15, 2013 | 09:39 AM
Fundem's Avatar
For me i noticed a tad more top end power.. and no sound difference that I can notice at all.
Old May 15, 2013 | 10:23 AM
Fundem's Avatar
nobody on the size? 2.25 or 2.50?
Old May 15, 2013 | 05:35 PM
scrim's Avatar
measure it
Old May 15, 2013 | 06:15 PM
dr_2010SV's Avatar
I don't believe having a Y-pipe will necessarily make it louder, it will alter it and probably make it sound a bit better.
I don't have a good answer for your size question but MF makes a couple of universal mufflers with tips that look pretty good. Part numbers are 14827 and 14829.
Old May 15, 2013 | 06:46 PM
dr_2010SV's Avatar
Racingline claims a performance increase but they don't documented it via dyno charts. The design concept for HP and torque increases make sense but who knows how much is actually realized (along with most performance mods) on this car without a proper tune.
Sound wise nothing major but there is a bit of difference. At idle it's subtle but to me it sounds more "pipey" for lack of a better term compared to the stock exhaust.
Old May 17, 2013 | 08:36 AM
Fundem's Avatar
I ordered 2.25" because that's whats stock, I hope it isn't 2.50". so it kind of slides onto the original piping then welded.
Old May 17, 2013 | 10:00 AM
dr_2010SV's Avatar
Yeah not sure if the MF muffler will be a direct fit as the stock max muffler has an offset inlet I believe.
My plan (if I ever get around to it) is to use the MF with integrated tip and just have the mufler shop bend new pipes and add a new attach flange at the Y so you would essentially have a axel back system that would bolt on in place of the stock set-up.
That way if you ever wanted to go back to the stock exhaust it would be as easy as a couple of bolts.
Edit: Yes the stock pipe is 2.25 if I remember correctly.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
TheMafia
Sep 4, 2015 08:26 AM
