Removing grille
Old Jun 21, 2013 | 04:28 PM
Grego214's Avatar
Removing grille
I'm sure this has been covered but I searched the forum and didn't find my answer.
The bottom two tabs in the middle of the grille are a pain in the *** and my hands are too big to fit between the foam piece and the tab. Does anyone have a solution to get these freakin tabs out?!
Old Jun 21, 2013 | 05:03 PM
Shipwreck's Avatar
I enlisted the aid of a small screwdriver. It was still difficult.
You could pull the bumper facia down a bit.
http://forums.maxima.org/7th-generat...eadlights.html
Old Jun 21, 2013 | 11:12 PM
Quinn'sMax's Avatar
I just removed the bumper.
Old Jun 23, 2013 | 08:02 AM
Grego214's Avatar
Thanks guys, dropping the bumper it is. Wanted to try out some plastidip.
Old Jun 23, 2013 | 03:12 PM
migonzo02's Avatar
You actually don't have to take the bumper off at all to plastic dip. I did it without having to take the bumper off at all. Look it up on here, or YouTube.
Old Jun 23, 2013 | 08:38 PM
Grego214's Avatar
I tried to spray some dip with the grille still on the car and putting cardboard in between and taping off the front and didn't get the results I wanted. I don't have a lot of space to work with in a garage so I had to spray it outside which I believe the wind caused it to have a bad result. I want to remove the grille and take it in the garage to get some good even coats.
Old Jun 24, 2013 | 11:35 AM
LudaTej's Avatar
I just plasti-dipped my grille this past weekend. Those 2 tabs you're talking about were indeed a pain in the a**. I tried using a flathead and a hook looking thing to get under the tab and pull up but neither worked. Eventually, I just kept yanking at it and I finally got frustrated to the point where I didn't care if the tabs broke. I don't know how the tabs came loose though but they did not break. Instead, I happened to break the top tab of the Nissan emblem while trying to pop that off.
Old Jun 24, 2013 | 11:46 AM
Boslax6123's Avatar
Aww man same exact thing happened to me lol. At the end it was fairly easy though.
Old Jun 24, 2013 | 11:51 AM
Ghozt's Avatar
Lots of struggling and cussing and I was able to get mine out. Probably would be easier with the bumper pulled forward a bit.
REDinLV
Aug 15, 2024 12:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
jaydot901
Sep 29, 2015 01:18 PM
ricky7780
Sep 24, 2015 06:50 PM
