00-03 Maxima Full LED Tail lights
Old Aug 29, 2013 | 10:20 PM
Genes1s's Avatar
I've been wanting to do LED turn signal for quite sometimes now. Recently got a decent pair of 5.5th gen tail lights from member here and started using these to Prototype the final product ( will be using SE Tails). There is similar LED tails out there for $250 at eBay, I'd figure this build would be a little bit cheaper plus it can function and look the way I want it. My goal is to make it as clean and OEM as possible. I will be using Phiips Lumiled RED HPWT-DH00 Superfluxes for the brake/stop light and HPWT-DL00 for turn signal.
http://www.philipslumileds.com/uploads/3/DS05-pdf
My crude wiring diagram for Brake/City
Red LED
with 33 ohm
with 33 + 220 ohm
Amber LED
With 33 ohm
With 33 Ohm + 220 Ohm
Taking apart the tail light
Damage the lens, the lens was attached using epoxy or some kinda perma seal, so combination heat and gentle prying were the way to do it
What it look like with the stock tail lens
Thinking of replacing those red and amber lens with smooth Red and amber polycarbonate ones. Most OEM application have smooth outside lens
Old Aug 30, 2013 | 05:20 AM
Prophecy99's Avatar
nice work, post your progress and final results.
That's a lot of work for what it's worth! aka dedication
Old Aug 30, 2013 | 01:11 PM
george__'s Avatar
good job!
Old Aug 30, 2013 | 01:50 PM
tosheto's Avatar
I am very interested to see the finished product. Good luck!
Old Aug 30, 2013 | 03:19 PM
rbaksi's Avatar
Very cool. Subscribed.
Old Aug 30, 2013 | 06:20 PM
tigersharkdude's Avatar
I came in here expecting some ebay junk tail lights ......
However, these look boss A.F!
In For Fin
Old Aug 30, 2013 | 07:15 PM
02whitemaximase's Avatar
Nice job, keep up the good work!
Old Aug 30, 2013 | 07:23 PM
T_Behr904's Avatar
Wow it looks great, and i'm not really into light mods, but I really like this.
Old Aug 30, 2013 | 10:14 PM
1996blackmax's Avatar
Good work!
Old Aug 31, 2013 | 10:17 AM
TunerMaxima3000's Avatar
awesome dude! hope to see finished pictures, bravo!
Old Aug 31, 2013 | 11:44 AM
picnik99's Avatar
this is great, I hope the finished product will turn out nice. good work so far man!
Old Aug 31, 2013 | 01:28 PM
Genes1s's Avatar
Thanks, I hope so too. You plan and plan again, contemplate, research, plan again and I finally said screw it, just go for it and see what's going to happen. The shape of the lens is kinda oblong/oval, so it was challanging to fill the area nicely. I would hate to see a single LED shining out from the rest. Another challange is how to open the light effectively. I destroyed the lens cover. Eventually I wan to do it in SE tails. If I didn't have to work on my Rear Trainling Arm bushing this weekend, I would hurry up and test the light at night...
Old Jan 15, 2014 | 08:54 AM
picnik99's Avatar
any updates on this project?
Old May 4, 2014 | 07:27 PM
Genes1s's Avatar
Ok,
I finally able to spend more time on my own project now...yeahaa.
so, for this LED project, I have few scenarios but now sure if it is the right thing to do..
I'm using collimator lens out of flash lights, you can find these at Ebay and other online LED shops. One of the best OEM LED tail lights is FX35's tail IMO. I'm trying to duplicate that performance using Collimator lens. Since the LED has 60 degree viewing angle already, I'm going to see if I can play with the focusing the beam by varying the distance between the collimator and the LED and find the perfect balance between intensity and uniformity.
1st option
Basically use the exisiting brake and turn signal bucket/area and fill it with LED. Top is brake/city light, bottom is turn signal, bottom left corner is reverse light.
2nd option, basically like option # 1 but with tinted lens. Looks really good IMO, although the tint is a little too dark for my taste
3rd option, A complete redesigned look. the 90 degree "Y" is the turn signal, inspired by the Lamborghini Aventador tail light design. The rest will be brake/city light with diffused lens ( no collimator). This can be done in red transparent lens and tinted lens on top or whatever color. I want a complete different look, but this design might be trying a little too hard......
It's going to be totally new look, but not sure if it goes together with the car.....
Old May 4, 2014 | 07:33 PM
King_Ten_Ahead's Avatar
Thats some fine work youve done right there. I like the uniqueness of the y and I feel that it would look sweet when driving at nighg. However the tinted lens looks better for daytime use IMO.
Cant go wrong with either though because of they both are nice looking!
Old May 4, 2014 | 08:59 PM
J3macks's Avatar
is it possible to just fill it with red led's and wire it so it acts as a 3 way lamp? running/brake/turn? i always wanted to do that but im not very skilled in this area
Old May 4, 2014 | 09:06 PM
Genes1s's Avatar
I'm not sure how, but I'm sure it can be done, probably with relay and PWM to control the brightness.
Old May 4, 2014 | 10:45 PM
Genes1s's Avatar
Here is more of a conventional look. Blue section in the middle will be clear turn signal. Looks simple and clean plus the possibility to do sequential turn signal
Old May 5, 2014 | 07:46 PM
J3macks's Avatar
im diggin it!
Old May 5, 2014 | 08:12 PM
SpeedCrazie's Avatar
Nice work brother!!
Old May 6, 2014 | 02:16 PM
MerlotMaxima's Avatar
Looks good so far
Old May 10, 2014 | 10:44 PM
Genes1s's Avatar
Finally decided to use the OEM lens. It looks so much cleaner. Still using collimator to get better focus.
Turn Signals CREE P4 at 40ma. Bare LEDS
With Collimator
Carbon Fiber strip (.060") on Acrylic lens for Parking Light, HP at 40mA Bare LEDs + Collimator
Final Design
Old May 10, 2014 | 10:50 PM
CMax03's Avatar
Pretty nice! Can't wait to see the finished project!
Old May 15, 2014 | 03:58 AM
SAK74's Avatar
I want to preorder a pair please. Thanks.
Old May 16, 2014 | 11:29 PM
Genes1s's Avatar
Got one brake light almost done. 21 LEDs, 2.7 Vf, 38mA using 33 ohm every 4 leds + 270 ohm for the last LED. 38mA seems really bright to me. I compared them to my Sienna OEM brake light and these are almost double. A stock brake bulb is typically 250-300 lumens. HPWTDH00 is 5 Lm at 70mA. Can I assume that the Lm is linear as the current goes down/up? .071 mA = 1 lumen?? thus 38 mA = 2.71 lm. If I have 21 bulbs that would be 21 * 2.71 = 57 Lm. This can't be right. It is brighter than my 21 W (250 Lm) OEM brake bulb for sure. Is there anyway to approximate the LED lumen output?
With Lens cover
Old May 16, 2014 | 11:41 PM
CMax03's Avatar
That's blinding!
Old May 17, 2014 | 08:35 PM
Zericmz's Avatar
Excellent work. For aesthetics, I liked the look of the tinted covers. It doesn't seem too dark to affect visual performance and with leds beneath it, I think it would be clearly visible.
Old May 17, 2014 | 09:52 PM
nismomaxgtr18's Avatar
Wow great work!
Old May 17, 2014 | 11:50 PM
Genes1s's Avatar
Stock Brake lights vs LED.
I decided to use the middle section between the brake and turn signal for Parking/City Light
Just got gluing turn signal LED to collimator and ready for wiring.
Old May 18, 2014 | 08:39 AM
These are incredible.
Old May 18, 2014 | 08:49 AM
03VQMAX's Avatar
When do they go on sale? Lmao
Old May 18, 2014 | 06:31 PM
Genes1s's Avatar
Gluing, cutting wires, soldering takes hours. Custom built one of these will be too much money I think unless I can figure out away to mold the collimator to the acrylic base and use flow oven with custom PCB to place the LEDs and Resistors.
I'll have seperate power supply unit that contain Vreg, Caps, and Diode as seperate unit.
Old May 18, 2014 | 10:49 PM
Genes1s's Avatar
Got the turn signal wired.
Added shield for the middle parking light to reduce the light bleeding.
Overall I'm pretty happy with how it turns out. Will build Vreg+Caps+Diode on seperate circuit and I can't wait to test it on the car.
Old May 19, 2014 | 10:23 PM
rbaksi's Avatar
Awesome project. Loving the updates
Old May 21, 2014 | 09:12 PM
Genes1s's Avatar
Not sure if this is the right thing to do, but it looks pretty good.
Plastidipped bezel. This is the first time I used plastidip and it is very forgiving. It has a nice texture too.
Old May 22, 2014 | 12:40 AM
dfj240's Avatar
What color did you decide to go with?
Old May 22, 2014 | 09:14 AM
Genes1s's Avatar
Color for?
Old May 22, 2014 | 07:49 PM
maximase86's Avatar
I love lamp.
It'd sure be cool to check this out tomorrow when I'm getting my headlights from you.
Old May 22, 2014 | 10:02 PM
dfj240's Avatar
Originally Posted by Genes1s
Color for?
The bezel. You said you plastidipped it. I was curious as to whether you used a unique color or just went with black.
Old May 22, 2014 | 10:50 PM
Genes1s's Avatar
It's just black, the only black they have at Lowes..
